1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: minimum CA Server requirements
To: [email protected]
Date: Fri, 1 Jul 2011 16:24:19 -0500
On 2011-06-30 Circuit6 Engineering wrote:
> I am very new to EPICS and only just started to work my way through the
> lectures, documentation and program text. I wonder how lean and trim a
> channel access server could be? For example, is it ridiculous to think
> about running CA Server on a 100MHz ARM Cortex-M3 with 256 KB flash
> memory, 64 KB SRAM and 10/100 Mbps Ethernet?
Hmm, interesting question, 256K of Flash and 64K of RAM seems pretty tiny
nowadays.  I have a pretty minimal CAS program which I build statically on
Linux; after I strip the binary, the executable is 702KB built for x86_64, and
817KB built for x86, and that doesn't include all the Linux system libraries.
I don't know how much smaller an ARM version might be, but I think it most
likely that the answer is no way with our current code, because you have to
allow for the rest of the OS as well.
As a comparison, compiling our example IOC application for the RTEMS-mvme3100
target (a 32-bit PowerPC CPU) results in a 1.6MB bootable binary image (which
includes the RTEMS OS code).  Now that's not using the same code as the CAS
program I was discussing above and it is actually a full IOC, but it gives
another minimal example.  I also looked at the boot images for several of our
ColdFire-based IOCs here, the bootable image for them are all in the 1.7-1.8MB
range too.
> I am also very new to RTEMS. If RTEMS is too heavy for a minimal hardware
> environment, could a trim CA server be ported to FreeRTOS with the lwIP
> (Lightweight IP) stack without serious re-engineering?
I think you'd be in the "serious re-engineering" range, although I don't know
anything about FreeRTOS or lwIP — I'm not saying that porting EPICS would
necessarily be that hard, but the code volume may be too big to overcome.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
minimum CA Server requirements Circuit6 Engineering
Prev: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Allison, Stephanie
Next: Re: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: minimum CA Server requirements Circuit6 Engineering
Next: Announce: sequencer 2.1.0 release candidate Benjamin Franksen
