1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: minimum CA Server requirements
To: [email protected]
Date: Thu, 30 Jun 2011 20:25:06 -0400
I am very new to EPICS and only just started to work my way through the lectures, documentation and program text. I wonder how lean and trim a channel access server could be? For example, is it ridiculous to think about running CA Server on a 100MHz ARM Cortex-M3 with 256 KB flash memory, 64 KB SRAM and 10/100 Mbps Ethernet?
I am also very new to RTEMS. If RTEMS is too heavy for a minimal hardware environment, could a trim CA server be ported to FreeRTOS with the lwIP (Lightweight IP) stack without serious re-engineering?
Thanks for any comments, speculations or pointers to reference materials!
Re: minimum CA Server requirements Andrew Johnson
Prev: Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Next: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Utzel Nadine
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Soft IOC hardware switch Eric Norum
Next: Re: minimum CA Server requirements Andrew Johnson
