1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Does EPICS Base support multi-thread on vxWorks 6.3?
To: [email protected]
Cc: [email protected]
Date: Thu, 30 Jun 2011 13:17:53 -0500
Hi Lorna,
On 2011-06-30 [email protected] wrote:
> We are not using the EPICS build system.
Do you use C++ in any of the other code you are running on vxWorks?  If EPICS
is the only source of C++ code in your system then your build system may not
be properly handling the initialization code for C++ static constructors and
destructors, which is what the munch process is for.  This is documented by
Wind River in their VxWorks Kernel Programmers Guide; for vxWorks 6.3 see
section 11.5 "Downloadable Kernel C++ Modules".
> Is it feasible that I copy your built vxTestHarness.munch to my vxWorks
> system, load it, and then run the test commands you've mentioned?
I don't have access to vxWorks 6.3, and I don't think any binary I build using
either vxWorks 5.5.2 or 6.8 would work properly on your version.  You will
have to build EPICS Base yourself using our build system.  You can find
instructions on the tools you need to do that on Windows at
    http://www.aps.anl.gov/epics/base/win32.php
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Prev: EPICS Soft IOC hardware switch Miroslav Mihaylov
Next: minimum CA Server requirements Circuit6 Engineering
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Next: Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
