1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Soft IOC hardware switch
To: Miroslav Mihaylov <[email protected]>
Cc: [email protected]
Date: Thu, 7 Jul 2011 15:07:14 -0700
I suggested to Miroslav that an easy way to get this sort of value into EPICS would be to buy a cheap USB mouse and wire the switch across one of the mouse buttons.  I've put together a small example showing how to read from a USB mouse into an EPICS PV.   It's very basic, but it does seem to work.  If anyone's interested I will e-mail the support module and example application to try out.
I've tested this only on OS X, but it should work on any system that supports libusb-1.0.
On Jun 30, 2011, at 9:17 AM, Miroslav Mihaylov wrote:
> Hello.
> I am looking for an EPICS compatible hardware switch that  has two enumerated
> PV values. For example when the switch is pressed its  PV value is 1 and when
> the switch is released its PV value is 0. I need to run that on a software IOC
> Linux box. I have Keythley multimeter and I could use one of its channels for
> that purpose but maybe someone else has already done something similar or
> there is an existing hardware solution that can run on soft IOC ?
> Thank you.
> Miroslav Mihaylov
> University of Illinois at Chicago
> Department of Physics
> 2336 SES
> 845 W. Taylor St. M/C 273
> Chicago, IL 60607
> 312 355 0225
Eric Norum
[email protected]
EPICS Soft IOC hardware switch Miroslav Mihaylov
Prev: RE: Errors building EPICS with MinGW Jeff Hill
Next: Re: PPC603 / PPC604 differences? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Soft IOC hardware switch Miroslav Mihaylov
Next: minimum CA Server requirements Circuit6 Engineering
