1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PPC603 / PPC604 differences?
To: Till Straumann <[email protected]>, Andrew Johnson <[email protected]>
Cc: [email protected]
Date: Fri, 08 Jul 2011 13:55:36 +0200
Till Straumann wrote:
Certainly, both CPUs support the mandatory PPC UISA instruction set.
Hence, if you compile code with -mcpu=powerpc then it should execute
on either of the CPUs.
However, the 604 e.g., implements fsqrt/fsrqts (FP square-root in
hardware) which are enabled when you compile with
-mdouble-float/-msingle-float (or implicitly when you use -mcpu=604)
There may be other optional instructions that the 604 has and the
603 does not and which you may want to use if you have a 604.
Does that mean that sqrt() is slower on a ppc604 when I use vxWorks-ppc32 because the hardware square root is not used?
Dirk
Re: PPC603 / PPC604 differences? Till Straumann
PPC603 / PPC604 differences? Dirk Zimoch
Re: PPC603 / PPC604 differences? Andrew Johnson
Prev: Re: EPICS Soft IOC hardware switch Eric Norum
Next: Re: PPC603 / PPC604 differences? Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PPC603 / PPC604 differences? Till Straumann
