I think I will have to defer to Dirk on this. If the underlying port is
still working, I don't understand why the record is stuck with PACT=1.
If you temporarily change the record from SCAN=Event to "1 second" does
it still hang up?
-----Original Message-----
Sent: Monday, July 11, 2011 1:24 PM
To: Mark Rivers; [email protected]; [email protected]
Subject: RE: streamdevice + asyn stuck
Hi Mark,
Thank you very much for spending time on this!
The SCAN field is "Event". I set up an event dispatcher to send out a
few
different events at certain rates. Those records listen to the events.
Those records talk to MKS937A controlers via digi port servers with TCP.
When the problem happens, the PACT field is "1", and the record is stuck
forever. But, the port is still active, other records can still use it.
Please help to correct my setup/configuration, so that when anything bad
happens, the record can recover in the next cycle. ( -- could it be
input
mismatch?)
Here is one example:
record(mbbi, "TST:DSU:GCC:01:STATE") {
field(DTYP, "stream")
field(INP, "@mks937a.proto.db state(2) TST:R54:GCT:16:B 0")
field(DESC, "Slot=A1")
field(SCAN, "Event")
field(EVNT, "1")
field(PHAS, "2")
field(FLNK, "TST:DSU:GCC:01:STATUSCALC")
part of the protocol file:
locktimeout = 5000;
terminator = CR;
replytimeout = 1000;
readtimeout = 1000;
extrainput = Ignore;
@init{out " ";}
state { out "R\$1"; in "%{\?.|
\?E|HI|A|Lo|F|H|W|L|CON|P|NOG|M|NOT|Not|C}"; }
asyn configure:
drvAsynIPPortConfigure("TST:R54:GCT:16:B", "TST-R59-SER-04:2104
TCP",0,0,0)
ioc-tst-vacuum> dbpr TST:DSU:GCC:01:STATE 10
ACKS: INVALID ACKT: YES ASG:
ASP: 0x0000000000000000 BKPT: 0x00 COSV:
NO_ALARM
DESC: Slot=A1 DISA: 0 DISP: 0 DISS:
NO_ALARM
DISV: 1 DPVT: 0x10c5fa0c00000000
DSET: 0x40c0df18db2a0000 DTYP: stream EIST: Below
Range
EISV: NO_ALARM EIVL: 0x0 ELST: No Gauge ELSV: MAJOR
ELVL: 0x0 EVNT: 1 FFST: Locked Out FFSV: MAJOR
FFVL: 0x0 FLNK:DB_LINK TST:DSU:GCC:01:STATUSCALC FRST: Low
Emission
FRSV: MAJOR FRVL: 0x0 FTST: Bad Command FTSV: MAJOR
FTVL: 0x0 FVST: Filament Off FVSV: MAJOR FVVL: 0x0
INP:INST_IO @mks937a.proto.db state(2) TST:R54:GCT:16:B 0 LALM: 0
LCNT: 11 LSET: 0x50ee070d00000000 MASK: 0
MLIS: 0x0000000000000000000000000000000000000000
MLOK: 0xc0d7bf0c00000000 MLST: 0
NAME: XXX:DSU:GCC:01:STATE NIST: Controlled NISV: MINOR
NIVL: 0x0 NOBT: 0 NSEV: NO_ALARM NSTA:
NO_ALARM
ONST: ON ONSV: NO_ALARM ONVL: 0x0 ORAW: 0
PACT: 1 PHAS: 2 PINI: NO
PPN: 0x0000000000000000 PPNR: 0x0000000000000000
PRIO: LOW PROC: 0 PUTF: 0
RDES: 0x6084830c00000000 RPRO: 0
RSET: 0xc02f2219db2a0000 RVAL: 0 SCAN: Event
SDEF: 1 SDIS:CONSTANT SEVR: INVALID SHFT: 0
SIML:CONSTANT SIMM: NO SIMS: NO_ALARM
SIOL:CONSTANT
SPVT: 0x6057100d00000000 STAT: SCAN SVAL: 0
SVST: Startup Delay SVSV: MINOR SVVL: 0x0 SXST: HV Off
SXSV: MAJOR SXVL: 0x0 TEST: Protected State
TESV: MINOR TEVL: 0x0 THST: At Atmosphere THSV: MINOR
THVL: 0x0 TIME: 2011-07-10 00:55:28.506299000 TPRO: 0
TSE: 0 TSEL:CONSTANT TTST: Wrong Gauge TTSV: MAJOR
TTVL: 0x0 TVST: Not Connected TVSV: MAJOR TVVL: 0x0
TWST: Above Range TWSV: MINOR TWVL: 0x0 UDF: 0
UNSV: MAJOR VAL: 0 ZRST: ON ZRSV:
NO_ALARM
ZRVL: 0x0
ioc-tst-vacuum> asynReport 10 TST:R54:GCT:16:B
TST:R54:GCT:16:B multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 1 exceptionNotifys 0
interposeInterfaceList
asynOctet pinterface 0x2adb18bbb1e0 drvPvt 0xc8a2b70
interfaceList
asynCommon pinterface 0x2adb18bb9100 drvPvt 0xc8a2070
asynOctet pinterface 0xc8a20e8 drvPvt 0xc8a2070
Port TST-R59-SER-04:2104 TCP: Connected
fd: 13
Characters written: 5368555
Characters read: 10201345
Thank you again, Best regards,
Dehong
Sent: Friday, July 08, 2011 8:28 PM
To: Zhang, Dehong; [email protected]; [email protected]
Hi Dehong,
We need more information:
- What is the .SCAN field of the record: it is periodic, I/O Intr,
Passive, etc?
- What type of device are you talking to: serial, TCP, etc?
canBlock=Yes is normal. It means that this is a "slow" device, and so
it uses asynchronous device support.
numberConnects is the number of times the device has been connected to.
It would normally be 1. If it is 2, that suggests the device has
disconnected, and then reconnects.
When it happens please send the complete output of "dbpr <record> 10"
Also send the complete output of "asynReport 10 <portName>"
Sent: Fri 7/8/2011 7:19 PM
Subject: streamdevice + asyn stuck
Hi Dirk, Mark and fellow EPICSers,
Sorry to bother you with this. I tried to chase the source code and
search the tech-talk,
but could not find much hints.
We use base 3.14.9, streamdevice 2.4 and asyn 4.10, have been
experiencing this stuck
problem for some time. The symptom is that randomly, a mbbi/ai/bi...
(input) record would
stop updating and no longer does FLNK, with no error/warning messages
printed in the log
file. And dbpr *** 3 would show that:
LCNT=11
SEVR=INVALID
STAT=SCAN
And manually writing to the PROC field also does nothing.
It seems like the record is stuck waiting for a callback from
streamdevice (and asyn), and
the EPICS framework just ignores any "PROC" requests.
In the protocol file we do have the timeouts etc:
locktimeout = 5000;
terminator = CR;
readtimeout = 1000;
While chasing the problem, I noticed that "asynReport 10 ***" would
show:
For some the numberConnects can be 2.
Is this "canBlock:Yes" related to my problem? Should the numberConnects
be <=1?
We use one port to talk to one device.
Rebooting the IOC does fix the problems, but then they would come back,
randomly.
Please advise. Thank you very much.
Best regards,
Dehong
- streamdevice + asyn stuck Zhang, Dehong
- RE: streamdevice + asyn stuck Mark Rivers
- RE: streamdevice + asyn stuck Zhang, Dehong
Re: SmarAct positioner control system Ernest L. Williams Jr.
<2011>
2025
2026
Re: streamdevice + asyn stuck Dirk Zimoch
<2011>
2025
2026
