1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS OSI and events
To: [email protected]
Date: Mon, 18 Jul 2011 16:37:06 +0200
On 18.07.2011 16:11, [email protected] wrote:
I see that there's a scanPause() function which can reset interruptAccept -- when does this get called?  I hope this isn't called normally!  (Scrabbling through the code suggests this is only called by iocPause(), which is just a command line debug hack, not for normal use, I hope...)
These calls are part of the API for redundant IOCs. One IOC is active, the other one is paused, and the redundancy module decides if it forces its IOC into pause mode.
As long as you don't run the redundancy stuff, you're safe.
~Ralph
EPICS OSI and events michael.abbott
RE: EPICS OSI and events Mark Rivers
RE: EPICS OSI and events michael.abbott
Prev: RE: EPICS OSI and events michael.abbott
Next: Alarm Handler and $ALARMCOUNTFILTER keith.baker
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS OSI and events Andrew Johnson
