Hi Michael,
On 2011-07-18 [email protected] wrote:
> the entire purpose of
> wait_for_epics_ready() is to ensure I can generate I/O Intr events without
> losing them. I wonder whether I should use initHookAfterInterruptAccept
> instead ... don't suppose it makes much difference.
It sounds like your interrupt routine should just be checking interruptAccept
and only generating I/O Intr events when it sees it true.
> On the other hand, I do have two problems with this:
> 1. Polling? Eww. In my particular example I guess it doesn't hugely
> matter, but it makes me queasy in general.
While I don't particularly like the use of the interruptAccept variable
because it's not strictly SMP-safe, that's how the original design worked and
it doesn't seem too easy to change — it is used a lot in device support. On
vxWorks at least it's often called from interrupt context where we can't use
semTake() or epicsMutexLock(), so we'd have to use a not-yet-available
epicsAtomic API to replace it (which could then be done with a suitable
macro).
> I see that there's a scanPause() function which can reset interruptAccept
> -- when does this get called? I hope this isn't called normally!
> (Scrabbling through the code suggests this is only called by iocPause(),
> which is just a command line debug hack, not for normal use, I hope...)
Ralph has explained why it's there; your "normal use" may not be the same as
someone else's, but that is a published IOC command and API (see iocInit.h).
To know exactly what the state of the IOC is you should listen for both
initHookAfterDatabaseRunning (equivalent to initHookAfterInterruptAccept but
which can occur more than once if someone calls iocPause and then iocRun) and
initHookAfterCaServerPaused, and have former start and the latter stop your
interrupt generation. However since this exactly is what interruptAccept is
for it's much easier to just use that...
Broadcast events are tricky on vxWorks, to do them properly (taking account of
the priorities of all the waiting threads etc.) really requires implementing
them inside the kernel. I think that's why we haven't provided an osi API for
them in libCom.
BTW, your wait_for_epics_ready() routine doesn't need to call malloc() [which
is worth avoiding on vxWorks < 6.x for memory fragmentation reasons], it could
allocate the waiter object on the stack since it's not going to return until
after the object has been de-queued anyway.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- RE: EPICS OSI and events michael.abbott
- EPICS OSI and events michael.abbott
- RE: EPICS OSI and events Mark Rivers
Alarm Handler and $ALARMCOUNTFILTER keith.baker
Re: Alarm Handler and $ALARMCOUNTFILTER Andrew Johnson
<2011>
2025
2026
Re: EPICS OSI and events Ralph Lange
<2011>
2025
2026
