1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Alarm Handler and $ALARMCOUNTFILTER
To: [email protected]
Date: Mon, 18 Jul 2011 11:14:15 -0500
Hi Keith,
On 2011-07-18 [email protected] wrote:
> My requirement is to only register an alarm if the value exceeds the
>  threshold persistently for 120 seconds.
> The other behaviour I've noticed is that once in alarm, the same criteria
>  is used to decide when to drop down to no alarm. i.e. if the PV value
>  drops below the threshold then it takes inputSeconds before this is
>  recognised, or inputCount drops within inputSeconds. I am just curious as
>  to whether this is behaviour that anybody wants or uses? I'd prefer to
>  drop out of the alarm state immediately.
It's likely that the behaviour implemented was required by someone at APS when
we wrote ALH, I see it being used fairly heavily in our operational alhConfig
files.
I would suggest that your alarm filter should probably be implemented inside
the IOC, rather than rely on ALH to do it.  It's much easier to customize
there anyway.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: Alarm Handler and $ALARMCOUNTFILTER keith.baker
Prev: Re: EPICS OSI and events Andrew Johnson
Next: RE: Delay problem in ca_array_put() command Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Alarm Handler and $ALARMCOUNTFILTER keith.baker
Next: RE: Alarm Handler and $ALARMCOUNTFILTER keith.baker
