Hi Lorna,
On 2011-07-21 you wrote:
> Finally, I'm able to build my own vxTestHarness.munch. I put it onto my
> vxWorks system, load it, and run the command epicsThreadPrivateTest, all 5
> tests passed.
> Now I have no idea what has caused our problem :(
That's what I expected to happen. The problem is that your build process is
*not* doing the munching step, thus the binary that you're creating for
vxWorks to load is not executing the C++ static constructors at load time.
Your code is probably all written in C which doesn't have anything equivalent
to static constructors, and as a result your code does not need to undergo the
munching step. Our code does contain C++ static constructors though, and will
not work properly if those to not get executed.
> Actually we DO use EPICS build system, to build the static libraries (.a
> files on vxWorks). And then we link all the static libraries that we need
> into a single dynamic library (.o file on vxWorks). I'm not sure if
> there's munching stuff happening during the linking process. Could that be
> the issue?
The munching stuff has to happen *after* the linking process. Once you have
all of the code linked into a single object file, you have to perform the
munch step on that file. The munching process will look through all of the
exported symbols in the file, extract those that are C++ static constructors,
and create a .c file containing a couple of functions which will execute all
those constructors as part of the vxWorks load step. You may have to use a
few special compiler switches when compiling that .c file, and you then link
the output of that compilation with your orignal object file to produce a file
that can be loaded on the vxWorks system.
These are the 4 commands that the EPICS build system uses to create a
vxTestHarness.munch file on my system. The object file that is the input to
the munch step is called vxTestHarness:
/usr/local/vw/vxWorks-6.8/utilities-1.0/x86-linux2/bin/nmppc vxTestHarness >
vxTestHarness.nm
perl ../../../../bin/linux-x86_64/munch.pl -o vxTestHarness_ctdt.c
vxTestHarness.nm
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -c
-DCPU=PPC32 -DvxWorks=vxWorks -include
/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-
align -mlongcall -fno-builtin -MMD -fdollars-in-identifiers -I. -I../O.Common
-I. -I.. -I../../../../include/os/vxWorks -I../../../../include -
I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -
I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ldppc -r -T
/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/tool/gnu/ldscripts/link.OUT -o
vxTestHarness.munch vxTestHarness_ctdt.o vxTestHarness
The munch.pl script that is the second command run above is part of EPICS
Base. Wind River provide an equivalent program called 'munch' which you
should find in your $WIND_BASE/vxworks-6.3/host/<host-arch>/bin directory but
it may need different command switches. As I said before, the VxWorks Kernel
Programmers Guide section 11.5 "Downloadable Kernel C++ Modules" has more
details and will show you how to use their munch program.
Please ask your Wind River representative if you need any further help with
this problem. You can also look at how the vxTestHarness.munch file gets
created on your system, it is made in the base/src/libCom/test directory.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
- Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
- Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
RE: Where is histogram? Dalesio, Leo
Re: Where is histogram? Andrew Johnson
<2011>
2025
2026
RE: Does EPICS Base support multi-thread on vxWorks 6.3? Jeff Hill
<2011>
2025
2026
