Actually, that's more what I was looking for, I think.
The idea is not to have a lot of dynamic libraries that have to be installed
on the machine that the IOC is installed on.
David
On 7/21/11 3:21 PM, "Andrew Johnson" <[email protected]> wrote:
> Hi David,
> On 2011-07-21 Eric Norum wrote:
>> The latter -- there's no way to static link (well, no *easy* way) on OS X.
>> On Jul 21, 2011, at 11:25 AM, David Dudley wrote:
>>> I seem to have discovered a problem on a MAC darwin-x86 where I can¹t
>>> static link programs.
>>> Whenever I try to set STATIC_BUILD=YES in the CONFIG_SITE file, and do a
>>> clean rebuild, it fails when it¹s trying to link antelope, saying that it
>>> can¹t find the crt0.0 library.
> That's the C run-time library, which Apple only provide as a dynamically-
> linked library.
> You should however be able to set SHARED_LIBRARIES=NO instead, and in your
> Base top directory do a 'make distclean' to remove all of the old .dylib files
> before you rebuild Base again. That will statically link in all of the EPICS
> libraries into the binaries it builds, but will still dynamically link the
> system libraries and thus overcome the above problem.
> HTH,
> - Andrew
David
"... The Crossbow Project. There's No Defense Like a Good Offense. " - Real
Genius (1985)
Don't think it exists? Google the Air Force X-37B project.
- Re: Static Linking... Andrew Johnson
color PV in edm Text Monitor Pierrick Hanlet
<2011>
2025
2026
Re: Static Linking... J. Lewis Muir
<2011>
2025
2026
