1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: color PV in edm Text Monitor
Date: Fri, 22 Jul 2011 09:33:01 +0100
Hi folks,
I have an EDM "Text Monitor".  It is meant to display a status: xxx:Status.
I use an associated (but different) PV which has alarm limits, as the color PV: xxx:iStatus
If I display the xxx:iStatus PV as a "Static Text" then it displays the color for an alarm
state on my EDM panel.  If I display the xxx:iStatus PV as the PV AND as the Color PV,
then it correctly displays the color for an alarm state.
However, it does not appear to set the color for "Text Monitor" when I display
xxx:Status as the PV and xxx:iStatus as the Color PV.
Am I doing something incorrectly, or is this feature not implemented in EDM?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Prev: Re: Static Linking... David Dudley
Next: Re: About CSS/BOY patard
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Static Linking... Eric Norum
Next: CSS training at Saclay 17-21 October 2011 Gougnaud Françoise
