1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: About CSS/BOY
To: patard <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 22 Jul 2011 13:10:19 -0400
Hi Charles,
> I already know this BOY functionality. It's true that my request
> wasn't quite clear. My aim is to make as simple as possible for
> Spiral2 operators and developpers. What could be simplestthan a click
> ? I have already written a JavaScript that forces an external window
> open when the user simply clicks on the button. I thought that it
> could be simpler to add an action property to force an external open.
I think the option to open an OPI in a new window should be used wisely, because too many windows will use too much system resources and it is very hard to manage them.
Optionally, you can also open an OPI in a View and then you can "detach/undetach" the view by right clicking the view tab and select "detached". See /BOY Examples/4_Actions_1.opi
> I've a other question for you Xihui. Is it possible to prevent the use
> of "Opi editor" when the CSS/BOY is in the runtime compact mode ? In
> this way the users haven't access to the development tools. They can
> only use the "Opi runtime" and can't exit this mode.
There is a BOY preference "No-Editing Mode". You can enable it to prevent opening an opi in opi editor.
Xihui
About CSS/BOY patard
RE: About CSS/BOY Chen, Xihui
Re: About CSS/BOY patard
Prev: USB/ASYN/EPICS example (usbMouse support) Eric Norum
Next: Re: Waveform Digitizers (Generic Transient Recorders) Lawrence T. Hoff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: About CSS/BOY patard
Next: About CSS/BOY patard
