1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on OS X Lion -- C++ problem
To: "'Eric Norum'" <[email protected]>, "'EPICS Tech Talk'" <[email protected]>
Date: Mon, 25 Jul 2011 18:41:02 -0600
Hi Eric,
What version of g++ is installed? I recently installed mingw 4.5.2 here. I
will update the R3.14 branch from Bazaar in the morning and verify that
everything builds ok.
Also, please send the complete error message. With C++ (in particular g++)
the error messages can be quite verbose, but nevertheless sometimes the
details are needed.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Eric Norum
> Sent: Monday, July 25, 2011 11:54 AM
> To: EPICS Tech Talk
> Subject: EPICS on OS X Lion -- C++ problem
> Downloaded and installed OS X Lion and the latest version of Xcode on my
> laptop machine.  Attempting to build EPICS results in:
> /usr/bin/c++ -c              -DUNIX  -Ddarwin     -O3 -g   -Wall      -
> arch i386    -fno-common -fPIC -MMD -I. -I../O.Common -I. -I.. -
> I../../../include/os/Darwin -I../../../include       -I/opt/local/include
> -I/sw/include  ../udpiiu.cpp
> ../udpiiu.cpp:1391: error: generic thunk code fails for method 'virtual
> int udpiiu::printFormated(epicsGuard<epicsMutex>&, const char*, ...)'
> which uses '...'
> Suggestions from C++ experts?
> Maybe I should be trying to build with clang instead of gcc?
> Eric Norum
> [email protected]
EPICS on OS X Lion -- C++ problem Eric Norum
Prev: Re: EPICS on OS X Lion -- C++ problem Eric Norum
Next: question regarding VxStats-1-7-2h (doesn't seem to measure CPU load properly) Jay Steele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS on OS X Lion -- C++ problem Jeff Hill
Next: RE: EPICS on OS X Lion -- C++ problem Jeff Hill
