1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on OS X Lion -- C++ problem
To: "'Noboru Yamamoto'" <[email protected]>, "'Eric Norum'" <[email protected]>
Cc: [email protected]
Date: Tue, 26 Jul 2011 12:07:33 -0600
> > /usr/bin/c++ --version
> > i686-apple-darwin11-llvm-g++-4.2 (GCC) 4.2.1 (Based on Apple Inc. build
> > 5658) (LLVM build 2335.15.00)
The R3.14 branch latest builds here for Intel w/o issues using this g++
version.
> g++ -v
Using built-in specs.
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=c:/mingw/bin/../libexec/gcc/mingw32/4.5.2/lto-wrapper.ex
e
Target: mingw32
Configured with: ../gcc-4.5.2/configure
--enable-languages=c,c++,ada,fortran,objc,obj-c++ --disable-sjlj-exceptions
--with-dwarf2 --enable-shared --enable-libgomp --disable-win32-registry
--enable-libstdcxx-debug --enable-version-sp
ecific-runtime-libs --disable-werror --build=mingw32 --prefix=/mingw
Thread model: win32
gcc version 4.5.2 (GCC)
> error: generic thunk code fails for method ?virtual
> int udpiiu::printFormated(epicsGuard<epicsMutex>&, const char*, ...)?
> which uses ?...?
Reading on the web, I think I understand what the issue is, but have some
trouble understanding why you see it and I don?t when surely it's the same
Intel target (but different OS)?
The workaround might be to pass stdarg instead of "...". I won't be able to
reproduce it here so perhaps I will commit a fix and then you can test?
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Noboru Yamamoto [mailto:[email protected]]
> Sent: Monday, July 25, 2011 8:33 PM
> To: Jeff Hill
> Cc: Eric Norum
> Subject: Re: EPICS on OS X Lion -- C++ problem
> (11/07/26 11:28), Noboru Yamamoto wrote:
> > Hi Jeff and Eric:
> > Here are info you asked in my environment (MacBook pro running MacOSX
> > 10.7 aka Lion):
> > (11/07/26 9:41), Jeff Hill wrote:
> >> Hi Eric,
> >> What version of g++ is installed? I recently installed mingw 4.5.2
> here. I
> >> will update the R3.14 branch from Bazaar in the morning and verify that
> >> everything builds ok.
> > [noboru-mbook:epics/R314/base] noboru% /usr/bin/c++ --version
> > Copyright (C) 2007 Free Software Foundation, Inc.
> > This is free software; see the source for copying conditions.  There is
> > NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> > PURPOSE.
> >> Also, please send the complete error message. With C++ (in particular
> g++)
> >> the error messages can be quite verbose, but nevertheless sometimes the
> >> details are needed.
> > make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
> > /usr/bin/c++ -c              -DUNIX  -Ddarwin     -O3 -g  -pipe -Wall
> >     -arch i386    -fno-common -fPIC -MMD -I. -I../O.Common -I. -I..
> > -I../../../include/os/Darwin -I../../../include       -I/usr/include
> > -I/opt/local/include  ../udpiiu.cpp
> > ../udpiiu.cpp:1392: error: generic thunk code fails for method ?virtual
> > which uses ?...?
> > make[3]: *** [udpiiu.o] Error 1
> > make[2]: *** [install.darwin-x86] Error 2
> > make[1]: *** [ca.install] Error 2
> > make: *** [src.install] Error 2
> > It will be nice if we can use c/c++ compiler supplied by Apple, so that
> > we can cretae Fat binary.
> Sorry,clang is also supplied by Apple.
> Apple clang version 2.1 (tags/Apple/clang-163.7.1) (based on LLVM 3.0svn)
> Target: x86_64-apple-darwin11.0.0
> Thread model: posix
> Noboru
> > Regards,
> > Noboru
> >> Jeff
> >>> From: [email protected] [mailto:tech-talk-
> [email protected]]
> >>> On Behalf Of Eric Norum
> >>> Sent: Monday, July 25, 2011 11:54 AM
> >>> To: EPICS Tech Talk
> >>> Subject: EPICS on OS X Lion -- C++ problem
> >>> Downloaded and installed OS X Lion and the latest version of Xcode on
> my
> >>> laptop machine.  Attempting to build EPICS results in:
> >>> /usr/bin/c++ -c              -DUNIX  -Ddarwin     -O3 -g   -Wall
> >>> arch i386    -fno-common -fPIC -MMD -I. -I../O.Common -I. -I.. -
> I/opt/local/include
> >>> -I/sw/include  ../udpiiu.cpp
> >>> ../udpiiu.cpp:1391: error: generic thunk code fails for method
> 'virtual
> >>> int udpiiu::printFormated(epicsGuard<epicsMutex>&, const char*, ...)'
> >>> which uses '...'
> >>> Suggestions from C++ experts?
> >>> Maybe I should be trying to build with clang instead of gcc?
> >>> Eric Norum
> >>> [email protected]
EPICS on OS X Lion -- C++ problem Eric Norum
RE: EPICS on OS X Lion -- C++ problem Jeff Hill
Prev: compile epics-base on cygwin-x86 as dynmaical lib Wang Xiaoqiang
Next: RE: EPICS on OS X Lion -- C++ problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS on OS X Lion -- C++ problem Jeff Hill
Next: Re: EPICS on OS X Lion -- C++ problem Andrew Johnson
