On 7/28/11 11:04 AM, Pierrick Hanlet wrote:
> Hi,
> I have an sseq record which I would like to use to fill both the value and
> the EGU field of another record. I'm OK with filling the value.
> Namely, I have a stringin record with value "Torr"; I'll call it myRecord:UNIT.
> I want to use myRecord:UNIT to fill the EGU field of another record. If
> I understand the documentation (I clearly don't), I ought to be able to do:
> field(DOLx,"myRecord:UNIT")
> field(LNKx,"anorhterRecord:P.EGU PP")
> I've tried numerous things, but nothing works. Please help. I'm at my wits end.
Hi, Pierrick.
It works for me. I loaded the attached database in a soft IOC
like this
dbLoadRecords("sseq-egu.db", "P=ioc23:")
and then did the following from a shell:
$ caget ioc23:Pressure.EGU
ioc23:Pressure.EGU
$ caput ioc23:SetPressureEgu.PROC 1
Old : ioc23:SetPressureEgu.PROC 0
New : ioc23:SetPressureEgu.PROC 1
ioc23:Pressure.EGU Torr
I suggest you try to reduce your database to as simple a
database as you can that exhibits the problem.
Lewis
# Sets record's EGU field from stringin record's VAL field using sseq.
# Parameters:
# $(P) PV name prefix (e.g. "ioc23:")
record(stringin, "$(P)Unit") {
field(VAL, "Torr")
field(PINI, "YES")
record(ai, "$(P)Pressure") {
field(VAL, "760")
field(PINI, "YES")
record(sseq, "$(P)SetPressureEgu") {
field(DOL1, "$(P)Unit.VAL NPP MS")
field(LNK1, "$(P)Pressure.EGU NPP MS")
- sseq record and strings Pierrick Hanlet
RE: Controls Network Monitoring Tools Zhou, Jingchen
EPICS Eric Norum
<2011>
2025
2026
Re: sseq record and strings Ralph Lange
EPICS Eric Norum
<2011>
2025
2026
