1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Erros running st.cmd
To: "'[email protected]'" <[email protected]>
Date: Fri, 5 Aug 2011 11:35:10 -0700
Hi all,
I just coded/compiled  an IOC for the first time.  Upon attempting to execute it, I am encountering the following errors….
[ui495a@macpro-fcid ...iocBoot/firstioc]$ ../../bin/cygwin-x86/firstioc st.cmd
#!../../bin/cygwin-x86/FirstIOC
## You may have to change FirstIOC to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","cygwin-x86")
envPaths -- Line 1 -- Command epicsEnvSet not found.
epicsEnvSet("IOC","firstioc")
envPaths -- Line 2 -- Command epicsEnvSet not found.
epicsEnvSet("TOP","c:/firstIOCtop")
envPaths -- Line 3 -- Command epicsEnvSet not found.
epicsEnvSet("EPICS_BASE","c:/EPICS/base")
envPaths -- Line 4 -- Command epicsEnvSet not found.
)acLib: macro TOP is undefined (expanding string cd ${TOP}
dbLoadDatabase "dbd/FirstIOC.dbd"
st.cmd -- Line 11 -- Command dbLoadDatabase not found.
FirstIOC_registerRecordDeviceDriver pdbbase
st.cmd -- Line 12 -- Command FirstIOC_registerRecordDeviceDriver not found.
## Load record instances
#dbLoadRecords("db/xxx.db","user=ui495aHost")
)acLib: macro TOP is undefined (expanding string cd ${TOP}/iocBoot/${IOC}
)acLib: macro IOC is undefined (expanding string cd ${TOP}/iocBoot/${IOC}
iocInit
st.cmd -- Line 18 -- Command iocInit not found.
## Start any sequence programs
#seq sncxxx,"user=ui495aHost"
epics>
I’m not sure if I am doing anything obviously wrong.  Any help/assistance will be greatly appreciated.
Thanks in advance,
F. Cid
Re: Erros running st.cmd Shen, Guobao
Prev: asyn R4-17 available Mark Rivers
Next: Re: Erros running st.cmd Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
