Is there a firewall running on that machine?
Is there a jcaLibrary.properties file that could be settings things for Java differently than the environment variables for the C utilities?
-----Original Message-----
Sent: Fri 8/19/2011 9:48 AM
To: [email protected]
Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues
Hello Kay,
Thanks for the advice but setting the IP address did not help, I am just
trying to access the variables on my own machine and have tried localhost
and 127.0.0.1. I did try the logging method and saw at first I was not
linking correctly to a shared library, but was able to fix the and no
longer have the error. I don't see any error message about the PV other
then it saying it is disconnected. I am attaching my log file to see if
that might help. Thanks once again for the help.
Cheers,
Adam Gluck | Applications Engineer | National Instruments
To: Adam Gluck <[email protected]>, "[email protected]"
<[email protected]>
Date: 08/18/2011 12:16 PM
to can be read through the terminal with no issues
Hi again:
Check the menu CSS/Preferences/CSS Core/EPICS for the auto addr. list and
addr list settings.
How do the settings compare to the EPICS_CA_*_ADDR_LIST environment
variables used by the command-line caget?
What if you de-select auto_addr_list and set the address list to the IP of
one of your IOCs? Do you then see the PVs on there?
a
broadcast address that includes one of your IOCs?
Kay
On 8/18/11 13:14 , "Kay Kasemir" <[email protected]> wrote:
> Hi:
> On 8/18/11 12:28 , "Adam Gluck" <[email protected]> wrote:
>> Hello All,
>> I have set up EPICS on a Scientific Linux 5.5 computer with the
>> 2.6.18-238.9.1.el5 kernel. I am using CSS to try and read the PV back
in
>> BOY. When I type the PV in the field then run the OPI it will display a
>> disconnected message and no values are read. If I do the call from the
>> terminal I can read the value back with no issue. I have also tried
this
>> on a Windows XP machine with the same results. Do you know what steps I
>> could take for further troubleshooting to find out why this is showing
>> disconnected? Or what other information would be helpful is
>> troubleshooting the problem. Thanks for the help.
>> Cheers,
- Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Ralph Lange
- Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
- Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Kasemir, Kay
- Re: EPICS BOY saying EPICS PV is disconnected even though to can be read through the terminal with no issues Adam Gluck
<2011>
2025
2026
<2011>
2025
2026
