1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading
To: [email protected]
Date: Fri, 19 Aug 2011 10:18:21 -0500
Hi Jay,
On 2011-08-19 Jay Steele wrote:
>      I also tested the ca_put_callback function to set the VAL field for
>  asyn motors, and only received the callback after the motor finished
>  moving to its command position. Is this expected behavior? I was hoping
>  for the callback to be received once the VAL field was set. Is there a way
>  to configure the channel access software to make this happen?
If you want to know when the VAL field has been set you should be able to use
ca_create_subscription() to monitor that or some other related record field.
One problem with using the motor.VAL field though is that it's used as both an
input (the user's demand position) and an output field (the current position),
so you'd get monitor events while the motor is moving.  That might not be what
actually want, so you should look at the other fields available and see if
monitoring one of them might be more appropriate for your purposes.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading J. Lewis Muir
question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Jay Steele
RE: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Jay Steele
Prev: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Kasemir, Kay
Next: Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: question about ca_get, ca_pend_io timeout in EPICS client withWindows XP multi-threading Mark Rivers
