1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading
Cc: [email protected]
Date: Fri, 19 Aug 2011 10:29:09 -0500
On 8/19/11 10:18 AM, Andrew Johnson wrote:
> If you want to know when the VAL field has been set you should be able to use
> ca_create_subscription() to monitor that or some other related record field.
> One problem with using the motor.VAL field though is that it's used as both an
> input (the user's demand position) and an output field (the current position),
> so you'd get monitor events while the motor is moving.  That might not be what
> actually want, so you should look at the other fields available and see if
> monitoring one of them might be more appropriate for your purposes.
Hi, Andrew.
Are you talking about the EPICS motor record?  The VAL field is
only updated after the move completes if certain logic makes it
get synced with the RBV field.  The VAL field does not update as
the motor moves.  The RBV field does.
Lewis
Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Andrew Johnson
question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Jay Steele
RE: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Jay Steele
Prev: Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Andrew Johnson
Next: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Adam Gluck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Andrew Johnson
