There was a firewall running that I disabled in order to get the command line caget to work. I did have 2 network cards with one if them set to inactive. I removed it to see if that would help but made no difference. I also disabled SELinux to see if that might have been interfering, but no luck. I also tried deleting the IP addresses other then 127.0.0.1 out of the setup. When I do I get another error in the log. I get this message: Failed to create transport for: /127.0.0.1:5064 com.cosylab.epics.caj.impl.ConnectionException: Failed to connect to '/127.0.0.1:5064'. I am also attaching the whole log that was generated. Thanks for the help everyone. Cheers, Adam Gluck | Applications Engineer | National Instruments From: "Kasemir, Kay" <[email protected]> To: "[email protected]" <[email protected]> Date: 08/19/2011 10:07 AM Subject: Re: EPICS BOY saying EPICS PV is disconnected even though to can beread through the terminal with no issues Sent by: [email protected] Hi: On 8/19/11 10:49 , "Mark Rivers" <[email protected]> wrote: > Is there a firewall running on that machine? I think he said a command-line caget on the same machine worked OK, but still worth trying. Does your computer have more than one network card? > Is there a jcaLibrary.properties file that could be settings things for Java > differently than the environment variables for the C utilities? Neither a jcaLibrary.properties file nor environment variables should matter. CSS is setting the JCA/CAJ libraries from Eclipse preferences ( http://sourceforge.net/apps/trac/cs-studio/wiki/HierarchicalPreferences ), i.e. basically what you see under CSS/Preferences/.../EPICS. From: [email protected] on behalf of Adam Gluck > Thanks for the advice but setting the IP address did not help, I am just > trying to access the variables on my own machine and have tried localhost > and 127.0.0.1. When using CAJ, make sure you try both with and without the "auto" address list in combination with "127.0.0.1". > I did try the logging method and saw at first I was not > linking correctly to a shared library, > but was able to fix the and no > longer have the error. What was that error? Did that only happen when you selected the JNI version of JCA, i.e. not the 'pure java' version under CSS/Preferences/.../EPICS -> That's expected unless you're running on the few architectures where we have the JNI binaries included. > I don't see any error message about the PV other > then it saying it is disconnected. I am attaching my log file to see if > that might help. Thanks once again for the help. The log file shows that you're using the "pure Java" JCA. Also: What's your CA server? Is it an ordinary IOC, or some other type of CA server? If you increase the log level (CSS/Preferences/...) to 'FINE' or higher, you should see more detail: PV channel created, connected, received meta data, .... Maybe that'll help. Thanks, Kay 2011-08-19 10:26:22.338 SEVERE [Thread 12] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
at com.cosylab.epics.caj.impl.CAConnector.connect(CAConnector.java:138)
at com.cosylab.epics.caj.CAJContext.getTransport(CAJContext.java:1438)
at com.cosylab.epics.caj.CAJContext.searchResponse(CAJContext.java:1415)
at com.cosylab.epics.caj.impl.handlers.SearchResponse.internalHandleResponse(SearchResponse.java:115)
at com.cosylab.epics.caj.impl.handlers.AbstractCAResponseHandler.handleResponse(AbstractCAResponseHandler.java:110)
at com.cosylab.epics.caj.impl.CAResponseHandler.handleResponse(CAResponseHandler.java:122)
at com.cosylab.epics.caj.impl.BroadcastTransport.processRead(BroadcastTransport.java:201)
at com.cosylab.epics.caj.impl.BroadcastTransport.handleEvent(BroadcastTransport.java:150)
at com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersHandler.handleEvent(LeaderFollowersHandler.java:71)
at com.cosylab.epics.caj.impl.reactor.Reactor.processInternal(Reactor.java:388)
at com.cosylab.epics.caj.impl.reactor.Reactor.process(Reactor.java:278)
at com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersHandler.run(LeaderFollowersHandler.java:85)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.net.UnknownHostException: EPICSlinux: EPICSlinux
at java.net.InetAddress.getLocalHost(InetAddress.java:1354)
at com.cosylab.epics.caj.impl.requests.HostNameRequest.<init>(HostNameRequest.java:42)
at com.cosylab.epics.caj.impl.CAConnector.connect(CAConnector.java:121)
... 14 more
2011-08-19 10:26:22.365 SEVERE [Thread 15] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.395 SEVERE [Thread 14] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.426 SEVERE [Thread 13] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.460 SEVERE [Thread 11] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.491 SEVERE [Thread 12] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.523 SEVERE [Thread 15] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.553 SEVERE [Thread 14] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.583 SEVERE [Thread 12] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.613 SEVERE [Thread 11] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:22.644 SEVERE [Thread 13] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:23.065 SEVERE [Thread 15] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
2011-08-19 10:26:23.092 SEVERE [Thread 14] com.cosylab.epics.caj.CAJContext (getTransport) - Failed to create transport for: /127.0.0.1:5064
... 14 more
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
