1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS (>=3.14.11) compiling problem on Snow Leopard (10.6.8)
To: <[email protected]>
Date: Fri, 19 Aug 2011 22:09:47 -0400
Title: EPICS (>=3.14.11) compiling problem on Snow Leopard (10.6.8)
Hi everyone,
When I tried to compile EPICS (3.14.12.1) against Snow Leopard (10.6.8), it ran into errors.
I patched all patches, but the problem was same (same problem for 3.14.11).
However, the R3.14.10 can be compiled smoothly.
Do I miss any library? Any suggestion?
The error is as below:
/usr/bin/cc -c           -DDEFAULT_SKELETON_FILE=include/flex.skel.static   -DUNIX  -Ddarwin     -O3 -g   -w      -arch i386    -fno-common  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Darwin -I../../../../include       -I/opt/local/include -I/sw/include  ../tblcmp.c
rm -f parse.c y.tab.c
rm -f parse.h y.tab.h
../../../../bin/darwin-x86/antelope -l -d ../parse.y
dyld: Symbol not found: _rl_insert
  Referenced from: /Users/xxxxx/V3/base/lib/darwin-x86/libCom.3.14.12.dylib
  Expected in: flat namespace
 in /Users/xxxxx/V3/base/lib/darwin-x86/libCom.3.14.12.dylib
make[4]: *** [parse.c] Trace/BPT trap
make[3]: *** [install.darwin-x86] Error 2
make[2]: *** [flex.install] Error 2
make[1]: *** [toolsComm.install] Error 2
make: *** [src.install] Error 2
Guobao
(Solved) RE: EPICS (>=3.14.11) compiling problem on Snow Leopard (10.6.8) Shen, Guobao
Prev: RE: question about ca_get, ca_pend_io timeout in EPICS client with Windows XP multi-threading Jay Steele
Next: (Solved) RE: EPICS (>=3.14.11) compiling problem on Snow Leopard (10.6.8) Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Announce: sequencer release 2.1.1 Benjamin Franksen
