1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: blockingSockTest error
To: Ron Sluiter <[email protected]>
Cc: EPICS <[email protected]>
Date: Wed, 24 Aug 2011 18:29:17 -0500 (CDT)
Hi Ron,
----- Original Message -----
> Is this a known EPICS base test harness error?
> > taskwdTest.t ............... ok
> > blockingSockTest.t ......... Bailout called. Further testing
> > stopped: Stop all CA servers before running this test.
> > FAILED--Further testing stopped: Stop all CA servers before running
> > this test.
The error message is telling you that you can't run blockingSockTest on a machine that currently has a CA server (such as a soft IOC) running on it.  I don't see the error normally.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson
blockingSockTest error Ron Sluiter
Prev: Re: Newbe question - PV limits Paul Nord
Next: Re: ether_ip driver for ControlLogix PLCs and 'BOOL' tags David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: blockingSockTest error Ron Sluiter
Next: Reboot VME problem Chen Xue
