1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Newbe question - PV limits
To: [email protected]
Date: Wed, 24 Aug 2011 17:01:28 -0500
Ron, good catch.  I was actually surprised by the variable values in my email.  It is correct in the code I copied it from.  (Or I'm going crazy.)
Here's the db printout:
epics> dbpr GROUP_0 5
ACKS: NO_ALARM      ACKT: YES           ADEL: 1             ALST: 5
ASG:                ASP: 0x00000000     BKPT: 0x00
DESC: SNMP channel BBM-                 DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DOL:CONSTANT        DPVT: 0x90ce2c08
DRVH: 5             DRVL: 4             DSET: 0x3098ecf7    DTYP: Snmp
EGU:                EVNT: 0             FLNK:CONSTANT 0     HHSV: NO_ALARM
HIGH: 0             HIHI: 0             HOPR: 5             HSV: NO_ALARM
HYST: 0             IVOA: Continue normally                 IVOV: 0
LALM: 4             LCNT: 0             LLSV: NO_ALARM      LOLO: 0
LOPR: 4             LOW: 0              LSET: 0x887d2d08    LSV: NO_ALARM
MDEL: 0             MLIS: 0x48d4310880b0310804000000        MLOK: 0xf8561f08
MLST: 4             NAME: GROUP_0       NSEV: NO_ALARM      NSTA: NO_ALARM
OMSL: supervisory
OUT:INST_IO @[xxx.xxx.xxx.xxx] guru WIENER-CRATE-MIB::groupsSwitch.0 INTEGER: 100 i
PACT: 0             PHAS: 0             PINI: YES           PPN: 0x00000000
PPNR: 0x00000000    PRIO: LOW           PROC: 0             PUTF: 0
RDES: 0x78361808    RPRO: 0             RSET: 0x0044ebf7    SCAN: Passive
SDIS:CONSTANT       SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SPVT: 0x00000000    STAT: NO_ALARM
TIME: 2011-08-24 17:57:55.505731000     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 0              VAL: 4
Paul
On Aug 24, 2011, at 4:53 PM, Ron Sluiter wrote:
> Doesn't HOPR(=4) need to be > LOPR(=5)?
> On 8/24/2011 4:10 PM, Paul Nord wrote:
>> I've got a GUI setup with MEDM to control some values.  I'd like to PV to accept values only in a valid range: 4 or 5.
>> Here's the record:
>> record(longout, "GROUP_0")
>>  field(DESC, "SNMP channel BBM-")
>>  field(DTYP, "Snmp")
>>  field(SCAN, "Passive")
>>  field(EGU,  "")
>>  field(PINI, "YES")
>>  field(OUT,  "@$(HOST) guru WIENER-CRATE-MIB::groupsSwitch.0 INTEGER: 100 i")
>>  field(ADEL, "1")
>>  field(VAL, "5")
>>  field(LOPR, "5")
>>  field(HOPR, "4")
>>  field(DRVH, "5")
>>  field(DRVL, "4")
>> I've tried setting LOPR, HOPR, and DRV*.  But I can still sent "1" from MEDM and it will set the hardware into an undesired mode.
>> I must be missing something simple here.
>> Paul
Newbe question - PV limits Paul Nord
Re: Newbe question - PV limits Ron Sluiter
Prev: Re: Newbe question - PV limits Ron Sluiter
Next: Re: blockingSockTest error Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Newbe question - PV limits emmanuel_mayssat
