1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 'open' epics backup?
To: emmanuel mayssat <[email protected]>
Cc: [email protected]
Date: Fri, 26 Aug 2011 10:54:49 -0500 (CDT)
----- Original Message -----
> From: "emmanuel mayssat" <[email protected]>
> To: "Tim Mooney" <[email protected]>
> Cc: [email protected], "Pete Jemian" <[email protected]>
> Sent: Thursday, August 25, 2011 6:41:09 PM
> > I use BURT for this.
> > http://www.aps.anl.gov/epics/extensions/burt/index.php
> Ok, for BURT without sdds.
> Just out of curiosity,
> 1/ can you restore a subset of your PVs instead of a complete restore?
The snapshot file is ascii, so you can use a text editor.  There's no
tool for this, as far as I know
> 2/ is there a utility to compare BURT snapshot?
I use diff or tkdiff.  I don't know of any more specialized tool
> 3/ How do you generate a req file? dbl + manual edit ?
Manual edit.
> 4/ what does the Notify means in the Read Only Notify (RON), a popup
> in the GUI? In which case would that be used?
I don't use that feature, so I'm probably not the best source for use
cases.  One use would be to handle PV's that need some special user
attention.  For example, you might need to put a system into a certain
state before writing to certain PVs.  RON would allow you to include
those PVs in the request file, and remind whomever uses the snapshot
that special attention is needed.
> 5/ How does BURT compares to CASR in your opinion?
Pretty similar.  In addition to read-only and read-only-notify, casr
implements write-only, which seems valuable.
I don't do very much backing up and restoring.  We used to put a lot
of effort into BURT request files for synApps, but our users sort of
migrated away from manual save/restore.
> Thanks,
> Emmanuel
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Re: 'open' epics backup? Pete Jemian
Re: 'open' epics backup? emmanuel_mayssat
Prev: RE: RDD of epics pv nick.rees
Next: Re: 'open' epics backup? Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 'open' epics backup? emmanuel_mayssat
