1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA issues on Linux
To: "'Cid, Florencio A'" <[email protected]>, <[email protected]>
Date: Thu, 1 Sep 2011 12:11:00 -0600
Some possible causes of trouble in this situation:
1)      There are multiple soft IOCs on this host _and_ EPICS_CA_AUTO_ADDR_LIST=NO _and_ the host IP for this host is in EPICS_CA_ADDR_LIST (this is a know limitation of typical ip kernels – see the CA ref manual). The only workaround currently is to configure clients to use broadcast when there are multiple soft iocs on one host, or alternatively to only run one soft ioc per host. I  have also implemented multicast support that fixes this issue, but the changes haven’t yet been merged it into a released version.
2)      There are some routing level issues – type “netstat –r”
3)      A local firewall is blocking the client’s search requests to port 5064, the soft IOC’s search responses to the client’s dynamically assigned port, or the client’s TCP connect requests.
4)      Something is amiss with CA’s auto configuration of its search address list (EPICS_CA_AUTO_ADDR_LIST=YES) on this version of linux. This can be investigated by calling the ca_client_status fuinction, passing a high interest level magnitude, from the test code.
5)      Issues with the exact spelling of the PV name
6)      A higher priority thread (than the ca server) in the soft IOC is using all of the cpu.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
From: [email protected] [mailto:[email protected]] On Behalf Of Cid, Florencio A
Sent: Thursday, September 01, 2011 11:18 AM
To: [email protected]
Subject: CA issues on Linux
Hi all,
I have an  IOC running on a Linux PC (Redhat Enterprise 16.1).  But, I am having difficulty getting  a test CA client (running on the same Linux PC) to communicate with the IOC.
Below are the errors being observed upon invoking the CA client.
[control@control linux-x86_64]$ ./caExample controlHost:floRec1
CA.Client.Exception...............................................
    Warning: "User specified timeout on IO operation expired"
    Context: "ca_pend_io failure"
    Source File: ../caExample.c line 20
    Current Time: Thu Sep 01 2011 10:29:54.965120461
    Warning: "Virtual circuit disconnect"
    Context: "ca_get failure"
    Source File: ../caExample.c line 21
    Current Time: Thu Sep 01 2011 10:29:54.965502001
controlHost:floRec1 0.000000
    Source File: ../caExample.c line 22
    Current Time: Thu Sep 01 2011 10:29:59.965721981
I tried searching the tech-talk archives, but couldn’t find anything related.   Any info/assistance will be greatly appreciated.
Thanks in advance,
F. Cid
RE: CA issues on Linux Cid, Florencio A
Prev: RE: CA issues on Linux Mark Rivers
Next: RE: CA issues on Linux Cid, Florencio A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
