1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: linux-x86_64 and linux-x86 architectures with different include files
To: <[email protected]>
Date: Thu, 8 Sep 2011 14:46:05 +0000
Hi all,
I'm looking at building areaDetector under both the linux-x86 and linux-x86_64 architectures, unfortunately the HDF5 libraries have slightly different headers for each architecture.
I know that I can do INC_Linux += ... to get different header files for each platform under include/os/Linux, but I can't work out if it's possible to install and use header files under include/os/linux-x86?
Does anyone have any ideas? In case it's useful I've attached a diff of the offending header file between 32 bit and 64 bit versions.
Tom Cobb
Index: ADApp/hdf5Support/os/Linux/H5pubconf.h
--- ADApp/hdf5Support/os/Linux/H5pubconf.h	(revision 67256)
+++ ADApp/hdf5Support/os/Linux/H5pubconf.h	(working copy)
@@ -511,7 +511,7 @@
 #define H5_PACKAGE_VERSION "1.8.6"
 /* Width for printf() for type `long long' or `__int64', use `ll' */
-#define H5_PRINTF_LL_WIDTH "ll"
+#define H5_PRINTF_LL_WIDTH "l"
 /* The size of `char', as computed by sizeof. */
 #define H5_SIZEOF_CHAR 1
@@ -538,10 +538,10 @@
 #define H5_SIZEOF_INT8_T 1
 /* The size of `int_fast16_t', as computed by sizeof. */
-#define H5_SIZEOF_INT_FAST16_T 4
+#define H5_SIZEOF_INT_FAST16_T 8
 /* The size of `int_fast32_t', as computed by sizeof. */
-#define H5_SIZEOF_INT_FAST32_T 4
+#define H5_SIZEOF_INT_FAST32_T 8
 /* The size of `int_fast64_t', as computed by sizeof. */
 #define H5_SIZEOF_INT_FAST64_T 8
@@ -562,10 +562,10 @@
 #define H5_SIZEOF_INT_LEAST8_T 1
 /* The size of `long', as computed by sizeof. */
-#define H5_SIZEOF_LONG 4
+#define H5_SIZEOF_LONG 8
 /* The size of `long double', as computed by sizeof. */
-#define H5_SIZEOF_LONG_DOUBLE 12
+#define H5_SIZEOF_LONG_DOUBLE 16
 /* The size of `long long', as computed by sizeof. */
 #define H5_SIZEOF_LONG_LONG 8
@@ -577,16 +577,16 @@
 #define H5_SIZEOF_OFF_T 8
 /* The size of `ptrdiff_t', as computed by sizeof. */
-#define H5_SIZEOF_PTRDIFF_T 4
+#define H5_SIZEOF_PTRDIFF_T 8
 /* The size of `short', as computed by sizeof. */
 #define H5_SIZEOF_SHORT 2
 /* The size of `size_t', as computed by sizeof. */
-#define H5_SIZEOF_SIZE_T 4
+#define H5_SIZEOF_SIZE_T 8
 /* The size of `ssize_t', as computed by sizeof. */
-#define H5_SIZEOF_SSIZE_T 4
+#define H5_SIZEOF_SSIZE_T 8
 /* The size of `uint16_t', as computed by sizeof. */
 #define H5_SIZEOF_UINT16_T 2
@@ -601,10 +601,10 @@
 #define H5_SIZEOF_UINT8_T 1
 /* The size of `uint_fast16_t', as computed by sizeof. */
-#define H5_SIZEOF_UINT_FAST16_T 4
+#define H5_SIZEOF_UINT_FAST16_T 8
 /* The size of `uint_fast32_t', as computed by sizeof. */
-#define H5_SIZEOF_UINT_FAST32_T 4
+#define H5_SIZEOF_UINT_FAST32_T 8
 /* The size of `uint_fast64_t', as computed by sizeof. */
 #define H5_SIZEOF_UINT_FAST64_T 8
@@ -696,7 +696,7 @@
 #endif
 /* Number of bits in a file offset, on hosts where this is settable. */
-#define H5__FILE_OFFSET_BITS 64
+/* #undef H5__FILE_OFFSET_BITS */
 /* Define for large files, on AIX-style hosts. */
 /* #undef H5__LARGE_FILES */
RE: linux-x86_64 and linux-x86 architectures with different include files Mark Rivers
Prev: RE: windows enable debug build Mark Rivers
Next: RE: linux-x86_64 and linux-x86 architectures with different include files Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: windows enable debug build Andrew Johnson
