1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: windows enable debug build
To: [email protected]
Date: Thu, 8 Sep 2011 10:03:01 -0500
Hi James,
On 2011-09-08 [email protected] wrote:
> Please can anyone tell me how to enable an EPICS R3.14.11 debug build for
>  win32-x86 (using Visual C++ 2003). I only get assembler in the debugger.
To expand on Mark's reply, edit your base/configure/CONFIG_SITE file and set
  CROSS_COMPILER_TARGET_ARCHS = win32-x86-debug
This will cause it to build both non-debug and debug versions of the code, and
you can then choose which you want to run based on the target architecture you
choose.  Don't forget to adjust your PATH to include the relevant
base/bin/<arch> directory or you'll be using the wrong DLLs.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
windows enable debug build james.rowland
Prev: RE: linux-x86_64 and linux-x86 architectures with different include files Mark Rivers
Next: RE: linux-x86_64 and linux-x86 architectures with different include files tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: windows enable debug build Mark Rivers
Next: linux-x86_64 and linux-x86 architectures with different include files tom.cobb
