1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynMotorController exception safety
To: "Mark Rivers" <[email protected]>, "Till Straumann" <[email protected]>, "EPICS Techtalk" <[email protected]>
Date: Tue, 13 Sep 2011 14:12:24 -0400
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: Tuesday, September 13, 2011 1:27 PM
> To: Till Straumann; EPICS Techtalk
> If your constructor throws an exception, does that automatically
result
> in a call to the destructor for the base classes?
Absolutely yes.
If the constructor of an object (or sub-object) completes then its
destructor will be called.  Sub-objects may be base classes, or member
objects.  This behavior why container classes can effectively manage
resources.
I think the basic problem is that asyn ports can't be unregistered.
When the asynPortDriver instance is destroyed it frees its
asynStandardInterfaces member structure.  This leaves asynManager
holding invalid pointers.
@Till, When I face this situation I set a flag if the constructor fails
which prevents the port from ever connecting.  Something like:
class myport : asynPortDriver {
  bool zombie;
myport::myport()
  : zombie(false)
try {
  // normal initialization
}catch(...){
  zombie=true;
myport::connect(){
  if(zombie)
    return asynError;
A better solution would be to avoid freeing asynStandardInterfaces.
Michael
> I would not have
> thought so, but I'm not enough of a C++ expert to know the answer to
> that.
> Mark
> From: Till Straumann [mailto:[email protected]]
> Sent: Tuesday, September 13, 2011 11:40 AM
> To: EPICS Techtalk; Mark Rivers
> Subject: asynMotorController exception safety
> I wrote a driver class derived from asynMotorController
> (which BTW was easy, thanks for the great package).
> I would like the driver to be robust in case e.g., of the
> absence of e.g., hardware or a serial communication channel.
> Hence, my class does something like:
> class MyDrv : public asynMotorController {
> public:
>      MyDrv() : asynMotorController(<parameters go here>)
>          status = detect_hardware(<parameters>);
>          if ( status ) {
>              throw MyException("HW detection failed\n");
> In my main application I create a driver object
> try {
>     new MyDrv();
> } catch (MyException &e) {
>     printf("Unable to create driver: %s\n", e.what());
> However, if hardware detection fails and the exception
> is thrown and subsequently caught then the IOC application
> will eventually (later) segfault in asynPortDriver::callbackTask()
> (when trying to lock the mutex). It seems that the work
> of the superclass constructor(s)
> (asynMotorController/asynPortDriver/...) is
> not properly undone.
> No segfault happens if I comment the entire try block
> (including the 'new' statement), i.e., if I create no
> driver at all (but still load the .db file etc.).
> How am I supposed to handle failure in the constructor?
> Thanks
> -- Till
Re: asynMotorController exception safety Till Straumann
RE: asynMotorController exception safety Mark Rivers
Prev: RE: asynMotorController exception safety Mark Rivers
Next: Re: asynMotorController exception safety Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
