Well - I'm not really working on this problem. I'm just
a 'user' of the asyn motor driver and I was hoping it
would 'behave the way I'd expect' but it turns out it
doesn't - so I live with some work-arounds...
T.
On 09/14/2011 04:26 AM, [email protected] wrote:
I'm fairly interested in this work... As well making asyn motor drivers robust against the problem of missing controllers at boot time, I'd also like to be able to automatically connect to a controller that has been attached, that wasn't present at original boot time. Although, I haven't really looked into this yet.
Cheers,
Matt
-----Original Message-----
[email protected]] On Behalf Of Till Straumann
Sent: 13 September 2011 19:22
To: Davidsaver, Michael
Cc: EPICS Techtalk
Subject: Re: asynMotorController exception safety
re: zombie - I'm aware of this technique but wanted
to make sure I'm not missing something.
Thanks
-- T.
[email protected]] On Behalf Of Mark Rivers
Sent: Tuesday, September 13, 2011 1:27 PM
To: Till Straumann; EPICS Techtalk
Subject: RE: asynMotorController exception safety
If your constructor throws an exception, does that automatically
result
in a call to the destructor for the base classes?
Absolutely yes.
If the constructor of an object (or sub-object) completes then its
destructor will be called. Sub-objects may be base classes, or
member
objects. This behavior why container classes can effectively manage
resources.
I think the basic problem is that asyn ports can't be unregistered.
When the asynPortDriver instance is destroyed it frees its
asynStandardInterfaces member structure. This leaves asynManager
holding invalid pointers.
@Till, When I face this situation I set a flag if the constructor
fails
which prevents the port from ever connecting. Something like:
class myport : asynPortDriver {
bool zombie;
myport::myport()
: zombie(false)
try {
// normal initialization
}catch(...){
zombie=true;
myport::connect(){
if(zombie)
return asynError;
A better solution would be to avoid freeing asynStandardInterfaces.
Michael
I would not have
thought so, but I'm not enough of a C++ expert to know the answer to
that.
Sent: Tuesday, September 13, 2011 11:40 AM
To: EPICS Techtalk; Mark Rivers
Subject: asynMotorController exception safety
I wrote a driver class derived from asynMotorController
(which BTW was easy, thanks for the great package).
I would like the driver to be robust in case e.g., of the
absence of e.g., hardware or a serial communication channel.
Hence, my class does something like:
class MyDrv : public asynMotorController {
public:
MyDrv() : asynMotorController(<parameters go here>)
status = detect_hardware(<parameters>);
if ( status ) {
throw MyException("HW detection failed\n");
In my main application I create a driver object
try {
new MyDrv();
} catch (MyException&e) {
printf("Unable to create driver: %s\n", e.what());
However, if hardware detection fails and the exception
is thrown and subsequently caught then the IOC application
will eventually (later) segfault in asynPortDriver::callbackTask()
(when trying to lock the mutex). It seems that the work
of the superclass constructor(s)
(asynMotorController/asynPortDriver/...) is
not properly undone.
No segfault happens if I comment the entire try block
(including the 'new' statement), i.e., if I create no
driver at all (but still load the .db file etc.).
How am I supposed to handle failure in the constructor?
Thanks
-- Till
- asynMotorController exception safety Till Straumann
- RE: asynMotorController exception safety Mark Rivers
- RE: asynMotorController exception safety Davidsaver, Michael
- Re: asynMotorController exception safety Till Straumann
- RE: asynMotorController exception safety matthew.pearson
RE: ioc linux crash using errlogprintf Davidsaver, Michael
Re: Another newbie question - seq record example? Paul Nord
<2011>
2025
2026
Does anyone have VMIC-3123A driver and device support in EPICS 3.14 version? Ma Xiaoyuan
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
