1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequence monitor not getting callback
To: <[email protected]>
Date: Fri, 16 Sep 2011 01:41:10 +0200
Am Freitag, 16. September 2011, um 00:50:04 schrieb Zelazny, Michael Stanley:
> >From time to time it appears as though my sequences don't get their monitor
callbacks.  Example:
> #42 of 196:
> Channel name: "KLYS:LI27:51:BVLT"
>   Unexpanded (assigned) name: ""
>   Variable name: "BVLT"
>     address = 203186364 = 0xc1c60bc
>     type = float
>     count = 1
>   Value = 0
>   Monitor flag = 0
>     Monitored
>   Assigned
>   Connected
>   Get not completed or no get issued
>   Put not completed or no put issued
>   Status = 0
>   Severity = 0
>   Message =
>   Time stamp = 2011/09/15 14:46:40.940
> Next? (+/- skip count)
> $ caget KLYS:LI27:51:BVLT KLYS:LI27:51:BVLT.MDEL
> KLYS:LI27:51:BVLT              349.717
> KLYS:LI27:51:BVLT.MDEL         0
> The PV is assigned with pvAssign and monitored with pvMonitor.
> The PV lives on the same soft ioc as the sequence.
> epics> dbpr("KLYS:LI27:51:BVLT",1000)
> ACKS: MAJOR         ACKT: YES           ADEL: 0             ALST:
> 350.166015625 AOFF: 0             ASG:                ASLO: 0
> ASP: 0xa7acfe8 BKPT: 00            DESC: Beam Voltage  DISA: 0
> DISP: 0 DISS: NO_ALARM      DISV: 1             DOL:CONSTANT        DPVT:
> (nil) DRVH: 0             DRVL: 0             DSET: 0x6bf280      DTYP:
> Soft Channel EGU:                EGUF: 0             EGUL: 0
> EOFF: 0 ESLO: 1             EVNT: 0             FLNK:DB_LINK
> KLYS:LI27:51:BVLTTS HHSV: NO_ALARM      HIGH: 360.000152587891
>      HIHI: 0 HOPR: 0             HSV: MAJOR          HYST: 0
> INIT: 0 IVOA: Continue normally                 IVOV: 0             LALM:
> 350.166015625 LBRK: 0             LCNT: 0             LINR: NO CONVERSION
> LLSV: NO_ALARM LOLO: 0             LOPR: 0             LOW: 0
> LSET: 0xb7b25dc8 LSV: NO_ALARM       MDEL: 0
> MLIS: 40 0a 70 8a d0 58 5b 0e 03 00 00 00                   MLOK: c8 b8 f0
> 09 MLST: 350.166015625 NAME: KLYS:LI27:51:BVLT                 NSEV:
> NO_ALARM NSTA: NO_ALARM      OIF: Full           OMOD: 0             OMSL:
> supervisory ORAW: 350           ORBV: 0             OROC: 0
> OUT:CONSTANT OVAL: 350.166015625 PACT: 0             PBRK: (nil)
> PHAS: 0 PINI: YES           PPN: (nil)          PPNR: (nil)         PREC:
> 6 PRIO: LOW           PROC: 0             PUTF: 0             PVAL:
> 350.166015625 RBV: 0              RDES: 0x81bbc50     ROFF: 0
> RPRO: 0 RSET: 0xf66840      RVAL: 350           SCAN: Passive
> SDIS:CONSTANT SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO
> SIMS: NO_ALARM SIOL:CONSTANT       SPVT: (nil)         STAT: NO_ALARM
> TIME: 2011-09-15 14:58:57.976294000     TPRO: 0             TSE: 0
> TSEL:CONSTANT       UDF: 0              VAL: 350.166015625
> More than 99% of the time, the sequence works great, but with 85 klystrons
> in SLAC's LCLS I see about 1 failure per month.  When the sequence starts
> one of its PVs appears to never get any callbacks.  If I restart the
> sequence, everything is fine.
> Using EPICS 3.14.12, sequencer 2.0.11, OS RHEL 4, update 8.
> Q: Has anyone else seen this?  If so, how did you fix it?
> I'm considering upgrading my sequencer to 2.1.2 based on Ben Franksen's
> notes about fixing bugs in pvAssign and "Safe mode".
I don't think use of pvAssign has anything to do with the problem (but I could
be wrong). Whether safe mode helps depends on whether access to a 'float' value
might be non-atomic on the system (OS, arch) on which your IOC and SNL program
run. Thus I need more data before I can judge conclusively.
I have heard the same complaint form at least one other user: sometimes
(monitor) events that should happen simply don't. I cannot guarantee that the
latest release (2-1-2) does not contain this or a similar bug. But the
internal workings of the sequencer have been cleaned up quite a bit since the
2-0-x versions, so it may well be that simply switching to the new version
fixes the problem. In any case, if it does /not/ do that, I can guaranteed that
I will be highly motivated to find out the reason for this and fix it ASAP.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: Sequence monitor not getting callback Zelazny, Michael Stanley
Prev: Sequence monitor not getting callback Zelazny, Michael Stanley
Next: How to write a python-based backpup tool? emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Sequence monitor not getting callback Zelazny, Michael Stanley
