1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics C# Library problems
To: Perrier Pierre <[email protected]>
Date: Thu, 22 Sep 2011 10:52:38 +0200
On Thu Sep 22 2011 10:41:42 GMT+0200 (CEST), Perrier Pierre <[email protected]> wrote:
Hello,
It’s what I’ve did for the monitor and it doesn’t seem to work. With this context I’ve tested the monitoring of a string waveform record which has a length 2 elements and all seems ok. I think that the problem is caused by the length of my waveform record which is 307,200
Cheers,
Pierre Perrier
Apologies if I'm too obvious...
EPICS_CA_MAX_ARRAY_BYTES is set in the environment on both client and server, and large enough to hold the array?
~Ralph
Epics C# Library problems Perrier Pierre
RE: Epics C# Library problems Bertrand Alain
RE: Epics C# Library problems Perrier Pierre
Prev: RE: Epics C# Library problems Perrier Pierre
Next: RE: Epics C# Library problems Bertrand Alain
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
