1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Epics C# Library problems
To: "Perrier Pierre" <[email protected]>
Cc: [email protected]
Date: Thu, 22 Sep 2011 11:34:08 +0200
Currently the client implementation we made support arrays up to 65K elements, as we use only the 16 bit element count. I didn't found yet how Epics sends over arrays bigger than that and until I find it, I can't implement a fix.
However I will try to check if there is some hints somewhere.
If somebody do have the info about how the header is constructed for bigger arrays (and at the same time for variable sized array) it would help me adding those features inside the library.
Sincerely,
Alain Bertrand
Sent: Thursday, September 22, 2011 10:42 AM
To: Bertrand Alain
Hello,
It’s what I’ve did for the monitor and it doesn’t seem to work. With this context I’ve tested the monitoring of a string waveform record which has a length 2 elements and all seems ok. I think that the problem is caused by the length of my waveform record which is 307,200
Cheers,
Pierre Perrier
De : Bertrand Alain [mailto:[email protected]]
Envoyé : jeudi 22 septembre 2011 08:54
À : Perrier Pierre; [email protected]
Objet : RE: Epics C# Library problems
For a simple get you should do the following:
EpicsClient client = new EpicsClient();
client.Config.ServerList.Clear();
client.Config.ServerList.Add("129.129.130.88:5064"); // replace with the broadcast address or with the server / gateway one
EpicsChannel<int[]> record = client.CreateChannel<int[]>("TOTO:INT");
int[] data = "">
for (int i = 0; i < data.Length; i++)
    if (i != 0)
        Console.Write(", ");
    Console.Write(i);
Console.WriteLine("");
For a monitor:
static void Main(string[] args)
    record.MonitorChanged += new EpicsDelegate<int[]>(record_MonitorChanged);
    Console.ReadKey();
static void record_MonitorChanged(EpicsChannel<int[]> sender, int[] newValue)
    for (int i = 0; i < newValue.Length; i++)
        if (i != 0)
        Console.Write(newValue[i]);
Personally I never use the Get function.
Cheers,
Alain Bertrand
From: [email protected] [mailto:[email protected]] On Behalf Of Perrier Pierre
Sent: Wednesday, September 21, 2011 4:40 PM
To: [email protected]
Subject: Epics C# Library problems
Hello,
I’m trying the EPICS C# Library in order to create a client to manage a Camera IOC. Unfortunately, I have some problems with the monitoring of waveforms records.
I want to monitor a waveform PV which contains data of a 640x480 gray scale picture (integers from 0 to 255). So it’s a large waveform of 307,200 elements. When  I process the following code, I catch a “Server did not respond in Time to Get Request” exception ( or , in debug mode,  the code doesn’t return).
EpicsClient m_client = new EpicsClient();
try{
                EpicsChannel<int> m_acquisitionCamera = m_client.CreateChannel<int>(“CameraJAI :Acquisition”) ;
                Int[] l_data = m_acquisitionCamera.Get<int[]>() ;
} catch (Exception e){
                System.Console.WriteLine(e.Message) ;
                System.Console.WriteLine(e.StackTrace) ;
Is there a way to fix this problem ? Any advices ? In order to really create a monitor, someone can show me a short sample of an EPICS C# monitor which manages an array record.
Best Regards,
Pierre PERRIER
Stagiaire - MCO LIL
Sopra group.
Parc Innolin
9 rue du Golf 33700 Merignac
Phone : +33 (0)5 56 12 79 59
[email protected] - www.sopragroup.com
Ce message peut contenir des informations confidentielles dont la divulgation est à ce titre rigoureusement interdite en l'absence d'autorisation explicite de l'émetteur. Dans l'hypothèse où vous auriez reçu par erreur ce message, merci de le renvoyer à l’émetteur et de détruire toute copie.
P Pensez à l’environnement avant d’imprimer.
RE: Epics C# Library problems Bertrand Alain
Epics C# Library problems Perrier Pierre
RE: Epics C# Library problems Perrier Pierre
Prev: Re: Epics C# Library problems Ralph Lange
Next: RE: Epics C# Library problems Bertrand Alain
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
