1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [S7plc EPICS driver] REAL type record jumps to zero
To: Pavel Masloff <[email protected]>
Cc: [email protected]
Date: Tue, 27 Sep 2011 08:35:40 -0500
I have other PLCs that I'm talking to though from the same machine
just a different soft IOC that do not have this same problem. For
some reason it is only this 1 PLC.
Marty
Pavel Masloff wrote:
Hey Marty!
Thanks for replying!
My IOC is running on a Red Hat Enterprise Linux 5 64-bit virtual machine (VMware Workstation). My S7plc-EPICS driver came with the CODAC 2.0 control system for ITER (including the Control System Studio framework and Self Description Data editor). So I can't say which version of the S7plc-EPICS driver I am using - couldn't find any readme file in the /EPICS/modules/s7plc folder.
I experience the same problem of losing connection between the IOC and the PLC every once in a while. But even if the connection is OK (the CFGSTAT.val of the DTYP "S7plc stat" is "Connected") and the counter of disconnections/reconnections is 0 - I still face the problem. Let alone I have other PVs (digital inputs -states and binary outputs -commands) that seem to be working OK. I even tried LONGIN record which worked.
Could it happen simply because we are using a Virtual Machine?
Pavel Maslov, MS
Efremov Institute / Pulsed Power Lab.
On Tue, Sep 27, 2011 at 2:36 PM, Marty Smith <[email protected] <mailto:[email protected]>> wrote:
    Hi Pavel,
    We are using the EPICS ether_ip driver version 2.23 under EPICS R3.14.11
    and are seeing the same thing when talking to a Allen Bradley
    Controligix
    PLC. I have not had enough time to look into the problem deep enough yet
    but every 20 minutes the data goes to zero and when that happens we are
    experiencing a loss of network between the soft IOC and the PLC
    hardware.
    The soft IOC is running on a linux-x86 64-bit virtual machine.
    We see that this does not happen if we are running the soft IOC on
    the old
    machine which is solaris but I don't have an explanation of why we
    don't see
    this same thing on both machines.
    We would like to get to the bottom of this so I'm going to try to
    look at the
    problem during this week in more detail.
    Marty Smith
    ANL / APS Controls Group
    ----- Original Message -----
    To: [email protected] <mailto:[email protected]>
    Sent: Tuesday, September 27, 2011 1:04:16 AM
    Subject: [S7plc EPICS driver] REAL type record jumps to zero
    Hello guys!
    My name is Paul and I work as Control Engineer at the Efremov
    Scientific Institute of Electro-physical Apparatus in St.
    Petersburg, Russia. We are currently involved in the ITER project,
    doing commutation switches for TF and PF superconducting coils. You
    might have heard of the largest Tokamak reactor being built in the
    south of France.
     From the control standpoint we are proposed to use EPICS control
    system and Siemens PLCs. Maybe you can help me for I have
    experienced some problems gathering data from PLC in to EPICS. To be
    specific, I collect REAL type data (electrical current) with a
    discretization of 100 ms (PLC send-cycle) and 300 ms (EPICS
    recvTimeout). Here is what I get in EPICS:
    Instead of a smooth staircase-shape curve with, say, 100 ms
    discretization (Fig. a) - my curve reaches zero periodically (Fig.
    b). So it's the same staircase-shape curve, but when the value
    changes, it becomes 0 beforehand. In other words, the last value is
    not retained. It is as if pulsing: value-0-value-0-value-0-etc.
    Maybe it can be better illustrated (see figures a and b, sorry for
    the quality). So I guess, it is due to this 200 ms differential -
    PLC sends data every 100 ms, EPICS receives data every 300 ms. Yet,
    it's proposed the EPICS recvTimeout to be 2 to 5 times the send
    intervall of the PLC. In my case it is 3.
    1) Fig. a
    0+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
    2) Fig. b
    0 ------ ------ ------
    What do you think might be the problem? Can the last value be
    retained by means of EPICS somehow. Because, from what I can see,
    EPICS thinks it is nothing (0) when there is no signal, whereas I
    need it to be at least the previous value to form a curve like on
    Fig. a.
    I have observed (in CSS BOY) that while this zero-jump the FLOAT32
    record was flashing READ_ALARM. This might be the case. But I have
    no idea how to fix this.
       • This is my db file:
    record (ai,"TEST-FDU-COMM:I_VCB")
    field(PINI, "YES")
    field(DTYP, "S7plc")
    field(INP, "@plc1_cfg/70 T=FLOAT32")
    field(SCAN, "I/O Intr")
    field(TSE, "-2")
    field(EGU, "Amps")
    field(PREC, "2")
    field(HIHI, "80000")
    field(HHSV, "MAJOR")
    field(HIGH, "70000")
    field(HSV, "MINOR")
    field(LOLO, "0")
    field(LLSV, "NO_ALARM")
    field(LOW, "2500")
    field(LSV, "MINOR")
       • Here is a line from the plcConfig.cfg file:
    s7plcConfigure plc1_cfg, 172.20.92.1, 2000, 86, 2, 1, 300, 100,
    "test REAL mode InWork 1"
       • PLC communicates via Ethernet cyclically every 100 ms (OB35 :
    Cyclic 100ms)
    It is interesting, though, that if I deal with data of other
    type(longin or bi), then there is no such a problem.
    Perhaps, the reason may lie within this data type itself (FLOAT32).
    Maybe, I should have gotten it in WORD-type instead and process
    afterwards. What do you think?
    Thanks in advance and I look forward to hearing from you!
    Sincerely,
    Pavel Maslov, MSc
    R&D Institute for Electro-Physical Apparatus
    Mobile: +7 (951) 672 22 19
    Phone: +7 (812) 461 01 01
Re: [S7plc EPICS driver] REAL type record jumps to zero Steven M. Hartman
[S7plc EPICS driver] REAL type record jumps to zero Pavel Masloff
Re: [S7plc EPICS driver] REAL type record jumps to zero Marty Smith
Re: [S7plc EPICS driver] REAL type record jumps to zero Pavel Masloff
Prev: Re: [S7plc EPICS driver] REAL type record jumps to zero Pavel Masloff
Next: looking for RFM2g driver for RTEMS Dan Eichel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [S7plc EPICS driver] REAL type record jumps to zero Steven M. Hartman
