1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [S7plc EPICS driver] REAL type record jumps to zero
To: "Martin L. Smith" <[email protected]>
Date: Tue, 27 Sep 2011 15:42:13 -0400
Martin L. Smith wrote:
I have other PLCs that I'm talking to though from the same machine
just a different soft IOC that do not have this same problem. For
some reason it is only this 1 PLC.
Marty--
Which ethernet module and firmware version are you using on your control logix PLCs? We've seen some buggy firmware versions which caused the PLC to occasionally drop its ethernet connection. Scanned ai records with ether_ip show a value of 0.0 with a READ error when the network connection is dropped.
Steven Hartman
[email protected]
Re: [S7plc EPICS driver] REAL type record jumps to zero Martin L. Smith
[S7plc EPICS driver] REAL type record jumps to zero Pavel Masloff
Re: [S7plc EPICS driver] REAL type record jumps to zero Marty Smith
Re: [S7plc EPICS driver] REAL type record jumps to zero Pavel Masloff
Prev: Xerces Re: problem running Channel Archiver on 64-bit Scientific Linux 6 Kasemir, Kay
Next: RE: [S7plc EPICS driver] REAL type record jumps to zero Di Maio Franck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [S7plc EPICS driver] REAL type record jumps to zero Martin L. Smith
Next: Re: [S7plc EPICS driver] REAL type record jumps to zero Martin L. Smith
