1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Xerces Re: problem running Channel Archiver on 64-bit Scientific Linux 6
To: Leonid Flaks <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 27 Sep 2011 15:25:32 -0400
Fellow tech-talkinans:
For the record, the problem turned out to be in the XML lib.
-Kay
On 9/27/11 15:08 , "Leonid Flaks" <[email protected]> wrote:
>I was able to re-compile archiver with xercesc library from ThirdParty
>(with your help!) and now I can start engine as it is supposed to be!
>Looks like the version of xercesc that comes with SL-6
>(xerces-c-3 . 0 . 1-20 . el6.x86_64) is not compatible with archiver code.
>I had to edit make.conf file to point to the proper 'library' and
>'include ' directories....
Prev: Re: Simple ADC - Ethernet device? Paul Nord
Next: Re: [S7plc EPICS driver] REAL type record jumps to zero Steven M. Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Fw: Simple ADC - Ethernet device? Mark Davis
Next: Transform Record no_inlink test Bruce Hill
