1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: Simple ADC - Ethernet device?
To: <[email protected]>
Date: Wed, 28 Sep 2011 07:20:29 -0400
----- Original Message ----- From: "Mark Davis" <[email protected]>
To: "Paul Nord" <[email protected]>
Sent: Wednesday, September 28, 2011 7:19 AM
Subject: Re: Simple ADC - Ethernet device?
For this sort of thing we tend to use Rabbit-based hardware (part of Digi) like this:
http://www.digi.com/products/wireless-wired-embedded-solutions/single-board-computers/bl2100#models
The software for these was developed in-house (by me) running on top of a small UNIX-like RTOS (also written by me when I got fed up with the vendor's offerings :-).
Details of the OS can be found here:
  http://groups.nscl.msu.edu/controls/
I am also putting the finishing touches on a paper and poster presentation for the upcoming ICALEPCS conference and I will add those to the above page soon.
We currently have hundreds of Rabbit modules running various controllers in the lab, many of which contain the Rabbit BL2105 Single Board Computer which has 11 12-bit ADC inputs and 4 12-bit DAC outputs. NOTE: The BL2105 is not actually listed on the Digi web site at this time but can still be purchased - the model # is important as the BL2105 contains 512K of RAM and 512K flash.
We also have several in-house designs that use the faster Rabbit Core Module RCM3200 and incorporate various numbers of 16-bit ADCs and DACs and digital I/O (mostly for controlling power supplies and motors).
Communication with all of these is over Ethernet and at present uses an Open-Modbus/TCP driver (also written in house - for some reason not currently listed on our public-access website, which it probably should be). There is also a (not quite finished) EPICS CA server for DEBROS, but I don't have any time frame for when it will be completed (probably not until higher priority stuff is addressed).
We have provided code and specs on our in-house designs to other labs in the past, so if you are interested any of that should be available as well. But if all you want is to monitor and/or control a handful of inputs and outputs (analog and/or digital), the BL2105 running DEBROS is probably the simplest of these options.
Mark Davis
NSCL
----- Original Message ----- From: "Paul Nord" <[email protected]>
Sent: Tuesday, September 27, 2011 10:38 AM
Subject: Simple ADC - Ethernet device?
I need to monitor the pressure in a gas supply bottle. We expect to need to change gas bottles every few days and we'd like to alert the detector operators in plenty of time.
Getting a transducer to produce a voltage is simple enough. I'm a little unclear about the next step: digitizing that voltage and getting that information to our EPICS softIOC. I'd like a simple box that connects to the voltage and also to an ethernet port.
There is an Epics driver for the environment monitor Websensor from Esensors Inc. It monitors temperature, humidity, and illumination. The device can also monitor a voltage reading. I presume it would be easy modify the driver to also get the voltage reading.
Is there another ethernet-based ADC that you would recommend?
There are some nice USB devices. But I don't really want to setup a computer just to monitor one voltage remotely.
I found some nice modular systems from Omega and NI. Alas, there are no Epics drivers.
Paul
Prev: RE: [S7plc EPICS driver] REAL type record jumps to zero Di Maio Franck
Next: Re: Transform Record no_inlink test Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Simple ADC - Ethernet device? Szalata, Zenon M.
Next: Xerces Re: problem running Channel Archiver on 64-bit Scientific Linux 6 Kasemir, Kay
