1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Transform Record no_inlink test
To: Tim Mooney <[email protected]>
Date: Wed, 28 Sep 2011 17:32:45 -0700
Hi Tim,
I tried the COPT "Always" setting and it doesn't work for me as it
re-computes and steps on the new values.    I've got a solution working
where I deleted the transform record input links and replaced my ao value
PV's with dfanout records that write to the transform record fields directly.
However, I think I'm still not understanding how the transform record
is intended to operate.
an input link disables the associated calculation
   because the value field will have been fetched by the record
   before the calculation was to be performed.
Each input link will fetch a value, but that code doesn't set the map bit,
and the new_value variable detects whether or not the value has changed.
It would seem to be safe to do the calculations for any new values whether
they came from input links or from direct writes to the transform record fields.
- Bruce
On 09/27/2011 04:05 PM, Tim Mooney wrote:
Bruce,
The transform record has two modes of operation.  The mode is
selected by the field COPT, which can take one of two values:
0) ("Conditional") do calculations only for fields that have
   not been written to since the last time the record processed.
   This is the default, because it's the behavior for which the
   record was originally written, and for backward compatibility
   with databases written before the COPT field was added.  In
   this mode, an input link disables the associated calculation
1)  ("Always") do all calculations regardless of whether fields
   have been written to.  This is relatively new, and it's the
   behavior you want.
In either mode it's ok for an output link to point to the same
PV as the associated input link.
The idea of conditional, by the way, is to separate value fields
into independent variables (written to) and dependent variables
(not written to; recalculated from independent variables), to
implement bidirectional coordinate transformations.  More
details are in the documentation:
https://subversion.xor.aps.anl.gov/synApps/calc/trunk/documentation/transformRecord.html
Tim
----- Original Message -----
To: [email protected]
Cc: [email protected]
Sent: Tuesday, September 27, 2011 5:05:16 PM
Subject: Transform Record no_inlink test
In using the transform record V5.7 from calc 2.8, I found that the
record has
a test in transformRecord.c line 398 that disables output calculations
for each variable that
has an input link.
If I disable that test for no_inlink, my transform record behaves as I
expect.
Does anyone know why that test is there?
It seems to preclude using the transform record input links which
select the same PV as the output links.
I can get around it by adding dfanout records to write the values
directly to the
transform record input fields, A-P, but it seems like an ugly
workaround.
- Bruce
record( ao, "$(CAM):Gain" )
field( DESC, "Set camera gain" )
field( DRVH, "100" )
field( DRVL, "0" )
field( HOPR, "100" )
field( LOPR, "0" )
field( PINI, "YES" )
field( FLNK, "$(CAM):Gain:Calc PP" )
record( ao, "$(CAM):GainA" )
field( DESC, "Gain for side A" )
field( DOL, "0x042" )
field( DRVL, "0x042" )
field( DRVH, "0x1E8" )
record( ao, "$(CAM):GainB" )
field( DESC, "Gain for side B" )
record( ao, "$(CAM):Gain:Offset" )
field( DESC, "Offset between gain halves" )
record( transform, "$(CAM):Gain:Calc" )
field( DESC, "Calc camera gain" )
field( INPA, "$(CAM):GainA" )
field( INPB, "$(CAM):GainB" )
field( INPH, "0x1E8" )
field( INPL, "0x042" )
field( INPO, "$(CAM):Gain:Offset" )
field( INPG, "$(CAM):Gain" )
field( CLCA, "(G/100)*(H-L)+L-(O/2)" )
field( CLCB, "(G/100)*(H-L)+L+(O/2)" )
field( CLCG, "(((A+B)/2)-L)*100/(H-L)" )
field( CLCO, "B-A" )
field( OUTA, "$(CAM):GainA PP" )
field( OUTB, "$(CAM):GainB PP" )
field( OUTG, "$(CAM):Gain PP" )
field( OUTO, "$(CAM):Gain:Offset PP" )
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Re: Transform Record no_inlink test Bruce Hill
Re: Transform Record no_inlink test Tim Mooney
Prev: Fw: Simple ADC - Ethernet device? Mark Davis
Next: Re: Sequence monitor not getting callback Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Transform Record no_inlink test Tim Mooney
Next: Re: Transform Record no_inlink test Bruce Hill
