1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Simple ADC - Ethernet device?
To: Paul Nord <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 27 Sep 2011 08:50:21 -0700
At SLAC we use Beckhoff Field Bus devices.  A typical set would consist of BK9000, KL3102, and KL9010.
BK9000 is the Ethernet coupler, KL3102 is a two channel differential input analog module (-10V to +10V), and KL9010 is a terminator.  These are not expensive.  The BK9000 uses Modbus protocol.  Beckhoff has a large array of Field Bus products.
I am using Modbus driver written by Mark Rivers.  A soft IOC consists of the afore mentioned driver, a handful of EPICS records, and configuration specified in the st.cmd file.
Zen
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Paul Nord
> Sent: Tuesday, September 27, 2011 7:38 AM
> To: [email protected]
> Subject: Simple ADC - Ethernet device?
> I need to monitor the pressure in a gas supply bottle.  We expect to need to
> change gas bottles every few days and we'd like to alert the detector operators
> in plenty of time.
> Getting a transducer to produce a voltage is simple enough.  I'm a little unclear
> about the next step: digitizing that voltage and getting that information to our
> EPICS softIOC.  I'd like a simple box that connects to the voltage and also to an
> ethernet port.
> There is an Epics driver for the environment monitor Websensor from
> Esensors Inc.  It monitors temperature, humidity, and illumination.  The device
> can also monitor a voltage reading.  I presume it would be easy modify the
> driver to also get the voltage reading.
> Is there another ethernet-based ADC that you would recommend?
> There are some nice USB devices.  But I don't really want to setup a computer
> just to monitor one voltage remotely.
> I found some nice modular systems from Omega and NI.  Alas, there are no
> Epics drivers.
> Paul
Simple ADC - Ethernet device? Paul Nord
Prev: Re: Simple ADC - Ethernet device? Dave Reid
Next: Re: Simple ADC - Ethernet device? Paul Nord
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Fw: Simple ADC - Ethernet device? Mark Davis
