1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: the seq that launched a thousand seqs
To: <[email protected]>
Date: Thu, 29 Sep 2011 12:41:31 +0200
Hi- sent as private email, but maybe of interest to the community...
Mike
-----Original Message-----
If you ever need to launch a thousand seqs "for real", you could do what
I'm doing: rather than a humungous startup file, have a separate small
state
set which reads a config file and calls seq() itself for each entry.
The
only fly in the metaphorical ointment appears to be that snl progs seem
to require at least one PV connection to be happy; with no PVs assigned
it complains about "0 out of 0" connections, so you need a dummy PV in
that state program (and Ben just told me that will be fixed in the next
release).
And fwiw, it's better to have the "startup" seq hibernate rather than
die, to ward off resource-destruction demons.
  // read -- read one config entry
  state read {
    when (1) {
%%    n = fscanf(fp,"%s %s %s",devName,devType,devCfg);
      if (n != 3) {
        if (feof(fp)) done = 1;
        else { //error
          bubu = 1;
    } state spawn
  // spawn -- spawn one magnet-cycling seq
  state spawn {
    when (done || bubu) {
      if (fp) fclose(fp);
    } state done
    when (1) {  // !done
%%      extern struct seqProgram seqMagCycle;
%%      char seqParms[99];
%%      sprintf(seqParms,"DEV=%s,TYP=%s,CFG=%s",devName,devType,devCfg);
%%      seq(&seqMagCycle,seqParms,0);
    } state spawn_delay
  // spawn_delay -- delay between spawns
  state spawn_delay {
#define SPAWN_DELAY 0.333  // adjust to taste
    when (SPAWN_DELAY) {
    } state read
Prev: Re: Transform Record no_inlink test Bruce Hill
Next: RE: building 64-bit base on windows Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: building 64-bit base on windows matthew.pearson
Next: Regarding Labjack and Xcode Kamleshkumar Suthar (suthar)
