1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequence monitor not getting callback
To: <[email protected]>
Date: Sun, 9 Oct 2011 23:51:03 +0200
Am Dienstag, 4. Oktober 2011, um 23:41:33 schrieb Shankar, Murali:
> Separating out the server (process variables) and the client (sequence
> programs) into two separate processes seems to fix this issue. I used the
> same executable for both processes; though for the server I could have
> probably used softIoc.
> So, the issue is perhaps the client part and the server part of
> ca_add_masked_array_event/ca_create_subscription tripping over each other
> if they run within the same process in this context.
Hi Murali
thanks a lot for tracking it down so far.
> I will test this workaround a little bit more. Any suggestions as to next
> steps for debugging are appreciated.
I am out of my depth here, but as Andrew I am certain that Jeff Hill has more
interesting comments to make about this. I am not certain but he'll probably
be at the ICALEPCS this week (i.e. until oct 14th).
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: Re: Sequence monitor not getting callback Shankar, Murali
Prev: EPICS Support for SRS RGA and OceanOpticas Jaz Spectrometer Tang, Johnny Y.
Next: mrfioc2 release 2.0.0 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequence monitor not getting callback Andrew Johnson
Next: How to write a python-based backpup tool? emmanuel_mayssat
