1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Sequence monitor not getting callback
To: "Shankar, Murali" <[email protected]>, "J. Lewis Muir" <[email protected]>
Date: Wed, 12 Oct 2011 11:42:32 -0700
Here's a couple of files with GDB back traces.
The file GDB_SequencerTest_Oct12_2011.txt contains "info threads" and "thread apply all bt" from a test involving sequence programs.
The file GDB_OnlyCA_Oct12_2011.txt "info threads" and "thread apply all bt" from a test involving only CA.
In both of these, the client and server ran in the same address space. In both of these, I launched the program, made sure we had the issue and then attached to the running process using "attach" from within gdb.
Please let me know if more info is needed or what the next steps are.
Murali
-----Original Message-----
Sent: Wednesday, October 12, 2011 10:40 AM
To: 'J. Lewis Muir'
Cc: Jeff Hill; [email protected]
Ok will do...
Murali
To: Shankar, Murali
Subject: Re: Sequence monitor not getting callback
On 10/12/11 12:18 PM, Shankar, Murali wrote:
> This is on linux so I will pop this into gdb and send you the relevant info offline.
Hi, Murali.
If there's nothing private, could you just keep everything on
the mailing list?  It's better for using the list archive in the
future and it's better for anyone following this problem to be
able to see what's going on, how it was investigated, and how it
was solved.
Thanks!
Lewis
Attachment: GDBThreadST_Oct12_2011.tar.gz
Description: GDBThreadST_Oct12_2011.tar.gz
RE: Sequence monitor not getting callback Jeff Hill
Re: Sequence monitor not getting callback Shankar, Murali
RE: Sequence monitor not getting callback Shankar, Murali
Re: Sequence monitor not getting callback J. Lewis Muir
Prev: RE: Sequence monitor not getting callback Shankar, Murali
Next: RE: Latest on archiving EPICS data Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Sequence monitor not getting callback Jeff Hill
