1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequence monitor not getting callback
To: <[email protected]>
Date: Thu, 13 Oct 2011 23:16:17 +0200
Am Donnerstag, 13. Oktober 2011, um 20:27:44 schrieb Shankar, Murali:
> Thank you. I tried this out on my dev box and /proc/cpuinfo happily reports
> only one CPU.
> The test with CA alone performs better in that it succeeds about 50% of the
> time. But a little less than 50% of the time, I still get monitors that
> have not received callbacks.
> The original test with sequence programs performs much better. So far, I
> have been able to reproduce the issue only once in about 10 tests. But the
> issue still occurs.
> I have attached the thread dumps as well.
Sorry for keeping silent so long, I was sick during the last days.
Jeff, you should note that one peculiarity of the problem is that those
channels that miss the initial event after connecting *never* again get one.
The "undelivered" number (from dbel output) just keeps increasing until it
stabilizes at
epics> dbel t1218 10
 VAL { VALUE ALARM } undelivered=96, thread=0x11214b0, unused entries=32,
discarded by replacement=150, duplicate count =95
when CA starts discarding new entries. At least that is what I observe here
(on a dual core AMD Phenom(tm) II X2 550 Processor running linux kernel
2.6.35-30). It should be possible to find out what is happening by looking
(with gdb) at the task that supposedly takes entries off the queue and sends
them to the client.
Anyway, if the client waits for all channels to receice their initial monitor
event before doing anything else, then the problem seems to disappear. In my
tests, I can decrease the probability of the bug happening by setting the SCAN
field of every record that has received one monitor to Passive. The dbel
output I pasted above comes from such a run: there was exactly this one record
remaining that produces events at all, all other 1999 records have been set to
Passive.
On the other hand, if I disconnect the channel after it has received its first
monitor event (using pvAssign(VAL,"") or by exiting the program) the
probability /increases/ greatly (i.e. I get much more channels that are in the
buggy state of never again receiving an event).
BTW, one of the reasons this was never observed before is that waiting for
initial monitor events is the default behaviour in SNL and practically
everyone leaves it at that. It is only because this feature is broken in
seq-2.1.2 that Mike couldn't "fix" this simply by enabling the +c option (i.e.
reverting to the default). The bug in seq-2.1.2 is that (by default or if
option +c is given) the sequencer only waits for connections to be stablished,
but not for the initial monitors. I will publish a new version that fixes this
problem (the trivial bug in the sequencer, not the subtle one in CA) as soon
as I feel fit enough.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Sequence monitor not getting callback Shankar, Murali
Re: Sequence monitor not getting callback J. Lewis Muir
RE: Sequence monitor not getting callback Shankar, Murali
Prev: RE: Sequence monitor not getting callback Shankar, Murali
Next: EPICS support for Granville Phillips Series 307 Vacuum Gauge Controller Linda.Pratt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Sequence monitor not getting callback Jeff Hill
