I've stumbled onto an interesting behavior of aSub. I want to write a
function which takes a CHAR array as input (a long string). Sometimes
the string can legitimately be empty (length 0). What I find is that
when the the input should go from non-empty to empty it does not, and
instead keeps the previous value.
In aSubRecord.c I see the following
for (i = 0; i < NUM_ARGS; i++) {
long nRequest = (&prec->noa)[i];
status = dbGetLink(&(&prec->inpa)[i], (&prec->fta)[i],
(&prec->a)[i], 0,
&nRequest);
if (nRequest > 0)
(&prec->nea)[i] = nRequest;
if (status)
return status;
http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/std/rec/aSubRecord.c#L321
I think what I am seeing is due to the "if (nRequest > 0)" test.
Is it ever the case that status==0 and nRequest==0 is used to signal an
error? If not then can this be changed? Perhaps to:
(&prec->a)[i], 0,
&nRequest);
if (status)
return status;
else
It looks like subArray does the right thing. However, soft device
support for waveform, and aai don't. They actually ignore status
completely!
http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/std/dev/devWfSoft.c#L72
Michael
- Re: aSub and zero length arrays Andrew Johnson
Re: Fwd: FW: EPICS driver for acqiris cPCI digitizer is available on epics.sf.net Silver
<2011>
2025
2026
<2011>
2025
2026
