1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build EPICS base-3.14.12.1-T222 in Linux problem.
To: Chen Xue <[email protected]>
Cc: [email protected]
Date: Tue, 18 Oct 2011 16:44:40 -0500
Hello Chen,
I'm guessing you are building the customized copy
of EPICS base that I've provided locally at APS.
These are the supported EPICS_HOST_ARCH's
  • solaris-sparc-v10-gnu-debug
  • solaris-x86-v10-gnu-debug
  • solaris-x86_64-v10-gnu-debug
  • linux-x86_64-el6-debug
  • linux-x86-el5-debug
  • vxWorks-ppc32-debug
I will try to put something on /APSshare that documents
the supported EPICS_HOST_ARCH's.
Ron
P.S. This is a question for the BCDA group here at the
APS; not tech-talk.
On 10/18/2011 4:07 PM, Chen Xue wrote:
Hi, there,
When I built EPICS base-3.14.12.1-T222 in Linux i386 (GNU Make 3.81), it gave the error message as below.
configure/CONFIG:62: configure/os/CONFIG.linux-x86.Common: No such file or directory
make:*** No rule to make target 'configure/os/CONFIG.linux-x86.Common'. Stop.
Could someone help me?
Thank you,
Chen
Build EPICS base-3.14.12.1-T222 in Linux problem. Chen Xue
Prev: Re: Build EPICS base-3.14.12.1-T222 in Linux problem. J. Lewis Muir
Next: EZCA and ezcaIDL improvements? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
