1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build EPICS base-3.14.12.1-T222 in Linux problem.
To: [email protected]
Date: Tue, 18 Oct 2011 16:07:44 -0500
Hi, there,
When I built EPICS base-3.14.12.1-T222 in Linux i386 (GNU Make 3.81), it gave the error message as below.
configure/CONFIG:62: configure/os/CONFIG.linux-x86.Common: No such file or directory make:*** No rule to make target 'configure/os/CONFIG.linux-x86.Common'. Stop.
Could someone help me?
Thank you,
Chen
Re: Build EPICS base-3.14.12.1-T222 in Linux problem. J. Lewis Muir
Re: Build EPICS base-3.14.12.1-T222 in Linux problem. Ron Sluiter
Prev: Re: aSub and zero length arrays Andrew Johnson
Next: Re: Build EPICS base-3.14.12.1-T222 in Linux problem. J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
