1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aSub and zero length arrays
To: [email protected]
Cc: [email protected]
Date: Tue, 18 Oct 2011 12:42:52 -0500
Hi Michael,
On 2011-10-18 Michael Davidsaver wrote:
> On 10/18/2011 11:30 AM, Andrew Johnson wrote:
> > The number of elements of a long string (char array) must always include
> > the terminating nil character, thus an empty string must have an element
> > count of one, not zero.  If you don't include the terminator in your
> > element count your string might get old garbage appended to it.
> Ok, so this covers the case of long strings.  What about other types
> (eg. DOUBLE)?  Isn't this an issue of general correctness/proper error
> reporting?
I believe there are a number of places in the dbAccess code that can't handle
zero-length arrays.  Passing a zero element count sometimes means just process
the attributes (alarm, timestamp etc.), don't copy any data elements at all; a
second call is used to access the data elements in those cases.
I'm not saying this is how I'd /like/ it to work, but it is how I believe some
parts of the code currently operate.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
aSub and zero length arrays Michael Davidsaver
Re: aSub and zero length arrays Andrew Johnson
Re: aSub and zero length arrays Michael Davidsaver
Prev: RE: How the EPICS IOC determines the link type {CA_LINK/DB_LINK/CONSTANT} Abadie Lana
Next: Build EPICS base-3.14.12.1-T222 in Linux problem. Chen Xue
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: aSub and zero length arrays Michael Davidsaver
