1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PVManager ReadOnly Check
To: "Kasemir, Kay" <[email protected]>, "Carcassi, Gabriele" <[email protected]>, <[email protected]>, <[email protected]>
Date: Thu, 20 Oct 2011 17:07:33 -0400
Title: RE: PVManager ReadOnly Check
In a channel connection to any client, a good client either implements a cache or a queue. The cache allows the client to decouple the update rate of the monitor from the update rate of the client - such as a GUI that only updates at 10 Hz - where the monitor returns at 60 Hz. The queue allows the client to collect a finite set of monitors and then act on many of them at once - such as a data archiver. There is no case that I can think of where it is a good idea for a client to not do either of these.
Or are you talking about the "get" and "put" operations?
-----Original Message-----
Sent: Thu 10/20/2011 3:22 PM
To: Carcassi, Gabriele; [email protected]; [email protected]
Hi:
> Something like PV.isWriteAllowed() from org . csstudio . utility . pv would be
> nice.
I would go even further:
Something like o.c.utility.pv would be nice, period.
The PV manager is great for applications that need to read the average over the last 10 seconds
from N channels, updating at 1 Hz on thread X, expecting a list of Double, while filtering on
only data where ... is ... .
That's really great.
But of course you can't "write" to those PVs because how would you change the average
over the last 10 seconds? Go back 8 seconds and adjust that original value?
The good news is that the PVManager internally uses a 'DataSource' API that is similar
to utility.pv: It's the raw channel; pluggable implementations for EPICS V3, simulated channels,
then EPICS V4, or whatever you want to add in the future.
If we allow access to both
a) the DataSource API for those who need/want/prefer a raw channel API to read and write
b) a PVManager API that can average, queue, schedule update rates, handle thread access
.. I think we'd have it all.
Kay
PVManager ReadOnly Check marcus . michalsky
RE: PVManager ReadOnly Check Carcassi, Gabriele
RE: PVManager ReadOnly Check Kasemir, Kay
Prev: RE: PVManager ReadOnly Check Carcassi, Gabriele
Next: FW: windows-x64 problem Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PVManager ReadOnly Check james.rowland
