Jeff,
I'm having a problem with DLLs on 64-bit Windows. I am building a DLL that will be called from IDL (similar to calling from Visual Basic). The DLL must have undecorated names for the entry points. For 32-bit Windows we have been using a .DEF file to achieve this, and it works fine. However, when we build for 64-bit Windows the names are undecorated by default, and I get a whole bunch of warnings if I use the .DEF file.
This is in the EPICS extension ezcaIDL. If I delete the .DEF file then 64-bit Windows builds fine, but the 32-bit build has decorated names and so does not work.
Have you seen this problem. Are we doing something wrong?
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release /MACHINE:X64 /manifest /implib:ezcaIDL
.lib /out:ezcaIDL.dll /def:../ezcaIDL.def ezcaIDL.obj ..\\..\\..\\lib\\windows-x64\\ezca.lib ..\\..\\..\\lib\\windows-x64\\EzcaScan.lib H:\\epics\\base-3.14.12.1\\lib\\windows-x64\\ca.lib H:\\epics\\base-3.14.12.1\\lib\\windows-x64\\Com.lib ws2_32.lib advapi32.lib user32.lib
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Zero' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Clear' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Add' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Get' specified multiple times; using first specification
Sent: Thu 10/20/2011 5:15 PM
To: Janet Anderson
Subject: RE: windows-x64 problem
Hi Janet,
No, IDL does not work with the decorated names. I built with no .DEF file. That creates undecorated names on 64-bit, but decorated names on 32-bit.
Now I assign the environment variable to the 64-bit DLL and run the 64-bit version of IDL. It works.
H:\epics\extensions_devel\src\ezcaIDL>set EZCA_IDL_SHARE=H:\epics\extensions_devel\bin\windows-x64\ezcaIDL.dll
H:\epics\extensions_devel\src\ezcaIDL>"c:\Program Files\ITT\IDL\IDL81\bin\bin.x86_64\idl.exe"
IDL Version 8.1, Microsoft Windows (Win32 x86_64 m64). (c) 2011, ITT Visual Information Solutions
IDL> t = caget('13BMD:m1', v)
IDL> print, t, v
0 -8.4500098
Now I assign the environment variable to the 32-bit DLL and run the 32-bit version of IDL. It fails.
H:\epics\extensions_devel\src\ezcaIDL>set EZCA_IDL_SHARE=H:\epics\extensions_devel\bin\win32-x86\ezcaIDL.dll
H:\epics\extensions_devel\src\ezcaIDL>"c:\Program Files\ITT\IDL\IDL81\bin\bin.x86_64\idl.exe" -32
IDL Version 8.1, Microsoft Windows (Win32 x86 m32). (c) 2011, ITT Visual Information Solutions
% CALL_EXTERNAL: Error loading sharable executable.
Symbol: ezcaIDLGetCountAndType, File = H:\epics\extensions_devel\bin\win32-x86\ezcaIDL.dll
The specified procedure could not be found.
% Execution halted at: CALL_EZCA 113 H:\idl_user\epics\ezcaIDL.pro
% CAGETCOUNTANDTYPE 324 H:\idl_user\epics\ezcaIDL.pro
% CAGET 479 H:\idl_user\epics\ezcaIDL.pro
% CALL_EZCA 111 H:\idl_user\epics\ezcaIDL.pro
% CAINIT 1666 H:\idl_user\epics\ezcaIDL.pro
% $MAIN$
So the linker must produce the undecorated names for IDL to be able to find them. That is why we used the .DEF file originally. What's strange is that the for 64-bits it creates undecorated names by default, and generates warnings if we supply a .DEF file.
Sent: Thu 10/20/2011 1:33 PM
To: Mark Rivers
Subject: Re: windows-x64 problem
Hi Mark,
I think it might be ok for the x86 names to be decorated and the x64 name to have no decoration.
Does the x86 dll work when created with NO def file? I thinks that the x86 decorations are different than x64decorations.
Janet
Mark Rivers wrote:
Hi Janet,
Something is strange here. I only get the warnings when I build for windows-x64, not when I build for win32-x86.
I then tried renaming ezcaIDL.def as you suggested. The eliminates the warnings. On windows-x64 the ezcaIDL.dll file looks fine, it is exporting the correct symbols:
H:\epics\extensions_devel\src\ezcaIDL>dumpbin /exports ..\..\bin\windows-x64\ezcaIDL.dll
Microsoft (R) COFF/PE Dumper Version 9.00.21022.08
Copyright (C) Microsoft Corporation. All rights reserved.
Dump of file ..\..\bin\windows-x64\ezcaIDL.dll
File Type: DLL
Section contains the following exports for ezcaIDL.dll
00000000 characteristics
4EA05FBD time date stamp Thu Oct 20 12:51:57 2011
0.00 version
1 ordinal base
53 number of functions
53 number of names
ordinal hint RVA name
1 0 00060A50 EzcaAddMonitorArray
2 1 00060760 EzcaCheckMonitorArray
3 2 000608E0 EzcaClearMonitorArray
4 3 0005FFC0 EzcaDebug
5 4 00060D70 EzcaGetArrayEventValues
6 5 00060DF0 EzcaGetArrayTypeCount
7 6 00060EB0 EzcaGetArrayValues
8 7 00060F80 EzcaGetError
9 8 00060820 EzcaGetMonitorArray
10 9 0005FFA0 EzcaInit
11 A 000600F0 EzcaMonitorQueue_Add
12 B 00060090 EzcaMonitorQueue_Clear
13 C 00060160 EzcaMonitorQueue_Get
14 D 00060030 EzcaMonitorQueue_Zero
15 E 00061130 EzcaMonitorScan_Add
16 F 00060B70 EzcaMonitorScan_Clear
17 10 00060B40 EzcaMonitorScan_Get
18 11 00060AE0 EzcaMonitorScan_Zero
19 12 00060260 EzcaPendEvent
20 13 00060BD0 EzcaPutArrayEventValues
21 14 00060CA0 EzcaPutArrayValues
22 15 00060190 EzcaSearchList
23 16 0005FF80 EzcaSetPendTime
24 17 00061090 EzcaTimeStamp
25 18 00060000 EzcaVersion
26 19 00060290 ezcaIDLAutoErrorMessageOff
27 1A 000602B0 ezcaIDLAutoErrorMessageOn
28 1B 000610B0 ezcaIDLClearMonitor
29 1C 00060310 ezcaIDLDebugOff
30 1D 00060330 ezcaIDLDebugOn
31 1E 00060350 ezcaIDLEndGroup
32 1F 00060480 ezcaIDLEndGroupWithReport
33 20 00060730 ezcaIDLGet
34 21 00061110 ezcaIDLGetControlLimits
35 22 00060590 ezcaIDLGetCountAndType
36 23 00060370 ezcaIDLGetEnumStrings
37 24 00060650 ezcaIDLGetErrorString
38 25 000610F0 ezcaIDLGetGraphicLimits
39 26 00060710 ezcaIDLGetPrecision
40 27 00060500 ezcaIDLGetRetryCount
41 28 000606F0 ezcaIDLGetStatus
42 29 00060520 ezcaIDLGetTimeout
43 2A 000606D0 ezcaIDLGetUnits
44 2B 00060570 ezcaIDLNewMonitorValue
45 2C 000606B0 ezcaIDLPerror
46 2D 00060620 ezcaIDLPut
47 2E 000605F0 ezcaIDLPutOldCa
48 2F 000610D0 ezcaIDLSetMonitor
49 30 00060540 ezcaIDLSetRetryCount
50 31 00060550 ezcaIDLSetTimeout
51 32 00060360 ezcaIDLStartGroup
52 33 000602D0 ezcaIDLTraceOff
53 34 000602F0 ezcaIDLTraceOn
Summary
17000 .data
8000 .pdata
22000 .rdata
2000 .reloc
1000 .rsrc
6E000 .text
Note the exported names are undecorated. However, the win32-x86 version is no good, the names are decorated. These were built on the same machine, same compiler, just changing the EPICS_HOST_ARCH and which vcvarsall.bat file was invoked. So it looks like the .def file is needed on 32-bit, but should not be used on 64-bit. Why?
H:\epics\extensions_devel\src\ezcaIDL>dumpbin/exports ..\..\bin\win32-x86\ezcaIDL.dll
Dump of file ..\..\bin\win32-x86\ezcaIDL.dll
File Type: DLL
4EA05FF7 time date stamp Thu Oct 20 12:52:55 2011
0.00 version
1 ordinal base
53 number of names
1 0 00049660 _EzcaAddMonitorArray@8 <mailto:_EzcaAddMonitorArray@8> <mailto:_EzcaAddMonitorArray@8>
2 1 00049590 _EzcaCheckMonitorArray@8 <mailto:_EzcaCheckMonitorArray@8> <mailto:_EzcaCheckMonitorArray@8>
3 2 00049620 _EzcaClearMonitorArray@8 <mailto:_EzcaClearMonitorArray@8> <mailto:_EzcaClearMonitorArray@8>
4 3 00048F60 _EzcaDebug@8 <mailto:_EzcaDebug@8> <mailto:_EzcaDebug@8>
5 4 000497E0 _EzcaGetArrayEventValues@8 <mailto:_EzcaGetArrayEventValues@8> <mailto:_EzcaGetArrayEventValues@8>
6 5 00049830 _EzcaGetArrayTypeCount@8 <mailto:_EzcaGetArrayTypeCount@8> <mailto:_EzcaGetArrayTypeCount@8>
7 6 00049880 _EzcaGetArrayValues@8 <mailto:_EzcaGetArrayValues@8> <mailto:_EzcaGetArrayValues@8>
8 7 000498D0 _EzcaGetError@8 <mailto:_EzcaGetError@8> <mailto:_EzcaGetError@8>
9 8 000495E0 _EzcaGetMonitorArray@8 <mailto:_EzcaGetMonitorArray@8> <mailto:_EzcaGetMonitorArray@8>
10 9 00048F40 _EzcaInit@8 <mailto:_EzcaInit@8> <mailto:_EzcaInit@8>
11 A 00049040 _EzcaMonitorQueue_Add@8 <mailto:_EzcaMonitorQueue_Add@8> <mailto:_EzcaMonitorQueue_Add@8>
12 B 00049000 _EzcaMonitorQueue_Clear@8 <mailto:_EzcaMonitorQueue_Clear@8> <mailto:_EzcaMonitorQueue_Clear@8>
13 C 00049090 _EzcaMonitorQueue_Get@8 <mailto:_EzcaMonitorQueue_Get@8> <mailto:_EzcaMonitorQueue_Get@8>
14 D 00048FC0 _EzcaMonitorQueue_Zero@8 <mailto:_EzcaMonitorQueue_Zero@8> <mailto:_EzcaMonitorQueue_Zero@8>
15 E 000499B0 _EzcaMonitorScan_Add@8 <mailto:_EzcaMonitorScan_Add@8> <mailto:_EzcaMonitorScan_Add@8>
16 F 00049700 _EzcaMonitorScan_Clear@8 <mailto:_EzcaMonitorScan_Clear@8> <mailto:_EzcaMonitorScan_Clear@8>
17 10 000496E0 _EzcaMonitorScan_Get@8 <mailto:_EzcaMonitorScan_Get@8> <mailto:_EzcaMonitorScan_Get@8>
18 11 000496A0 _EzcaMonitorScan_Zero@8 <mailto:_EzcaMonitorScan_Zero@8> <mailto:_EzcaMonitorScan_Zero@8>
19 12 00049160 _EzcaPendEvent@8 <mailto:_EzcaPendEvent@8> <mailto:_EzcaPendEvent@8>
20 13 00049740 _EzcaPutArrayEventValues@8 <mailto:_EzcaPutArrayEventValues@8> <mailto:_EzcaPutArrayEventValues@8>
21 14 00049790 _EzcaPutArrayValues@8 <mailto:_EzcaPutArrayValues@8> <mailto:_EzcaPutArrayValues@8>
22 15 000490C0 _EzcaSearchList@8 <mailto:_EzcaSearchList@8> <mailto:_EzcaSearchList@8>
23 16 00048F20 _EzcaSetPendTime@8 <mailto:_EzcaSetPendTime@8> <mailto:_EzcaSetPendTime@8>
24 17 00049910 _EzcaTimeStamp@8 <mailto:_EzcaTimeStamp@8> <mailto:_EzcaTimeStamp@8>
25 18 00048F90 _EzcaVersion@8 <mailto:_EzcaVersion@8> <mailto:_EzcaVersion@8>
26 19 00049180 _ezcaIDLAutoErrorMessageOff@8 <mailto:_ezcaIDLAutoErrorMessageOff@8> <mailto:_ezcaIDLAutoErrorMessageOff@8>
27 1A 00049190 _ezcaIDLAutoErrorMessageOn@8 <mailto:_ezcaIDLAutoErrorMessageOn@8> <mailto:_ezcaIDLAutoErrorMessageOn@8>
28 1B 00049930 _ezcaIDLClearMonitor@8 <mailto:_ezcaIDLClearMonitor@8> <mailto:_ezcaIDLClearMonitor@8>
29 1C 000491C0 _ezcaIDLDebugOff@8 <mailto:_ezcaIDLDebugOff@8> <mailto:_ezcaIDLDebugOff@8>
30 1D 000491D0 _ezcaIDLDebugOn@8 <mailto:_ezcaIDLDebugOn@8> <mailto:_ezcaIDLDebugOn@8>
31 1E 000491E0 _ezcaIDLEndGroup@8 <mailto:_ezcaIDLEndGroup@8> <mailto:_ezcaIDLEndGroup@8>
32 1F 00049300 _ezcaIDLEndGroupWithReport@8 <mailto:_ezcaIDLEndGroupWithReport@8> <mailto:_ezcaIDLEndGroupWithReport@8>
33 20 00049560 _ezcaIDLGet@8 <mailto:_ezcaIDLGet@8> <mailto:_ezcaIDLGet@8>
34 21 00049990 _ezcaIDLGetControlLimits@8 <mailto:_ezcaIDLGetControlLimits@8> <mailto:_ezcaIDLGetControlLimits@8>
35 22 00049400 _ezcaIDLGetCountAndType@8 <mailto:_ezcaIDLGetCountAndType@8> <mailto:_ezcaIDLGetCountAndType@8>
36 23 00049210 _ezcaIDLGetEnumStrings@8 <mailto:_ezcaIDLGetEnumStrings@8> <mailto:_ezcaIDLGetEnumStrings@8>
37 24 000494A0 _ezcaIDLGetErrorString@8 <mailto:_ezcaIDLGetErrorString@8> <mailto:_ezcaIDLGetErrorString@8>
38 25 00049970 _ezcaIDLGetGraphicLimits@8 <mailto:_ezcaIDLGetGraphicLimits@8> <mailto:_ezcaIDLGetGraphicLimits@8>
39 26 00049540 _ezcaIDLGetPrecision@8 <mailto:_ezcaIDLGetPrecision@8> <mailto:_ezcaIDLGetPrecision@8>
40 27 00049360 _ezcaIDLGetRetryCount@8 <mailto:_ezcaIDLGetRetryCount@8> <mailto:_ezcaIDLGetRetryCount@8>
41 28 00049520 _ezcaIDLGetStatus@8 <mailto:_ezcaIDLGetStatus@8> <mailto:_ezcaIDLGetStatus@8>
42 29 00049380 _ezcaIDLGetTimeout@8 <mailto:_ezcaIDLGetTimeout@8> <mailto:_ezcaIDLGetTimeout@8>
43 2A 00049500 _ezcaIDLGetUnits@8 <mailto:_ezcaIDLGetUnits@8> <mailto:_ezcaIDLGetUnits@8>
44 2B 000493E0 _ezcaIDLNewMonitorValue@8 <mailto:_ezcaIDLNewMonitorValue@8> <mailto:_ezcaIDLNewMonitorValue@8>
45 2C 000494E0 _ezcaIDLPerror@8 <mailto:_ezcaIDLPerror@8> <mailto:_ezcaIDLPerror@8>
46 2D 00049470 _ezcaIDLPut@8 <mailto:_ezcaIDLPut@8> <mailto:_ezcaIDLPut@8>
47 2E 00049440 _ezcaIDLPutOldCa@8 <mailto:_ezcaIDLPutOldCa@8> <mailto:_ezcaIDLPutOldCa@8>
48 2F 00049950 _ezcaIDLSetMonitor@8 <mailto:_ezcaIDLSetMonitor@8> <mailto:_ezcaIDLSetMonitor@8>
49 30 000493A0 _ezcaIDLSetRetryCount@8 <mailto:_ezcaIDLSetRetryCount@8> <mailto:_ezcaIDLSetRetryCount@8>
50 31 000493C0 _ezcaIDLSetTimeout@8 <mailto:_ezcaIDLSetTimeout@8> <mailto:_ezcaIDLSetTimeout@8>
51 32 00049200 _ezcaIDLStartGroup@8 <mailto:_ezcaIDLStartGroup@8> <mailto:_ezcaIDLStartGroup@8>
52 33 000491A0 _ezcaIDLTraceOff@8 <mailto:_ezcaIDLTraceOff@8> <mailto:_ezcaIDLTraceOff@8>
53 34 000491B0 _ezcaIDLTraceOn@8 <mailto:_ezcaIDLTraceOn@8> <mailto:_ezcaIDLTraceOn@8>
Summary
13000 .data
14000 .rdata
8000 .reloc
1000 .rsrc
Sent: Thu 10/20/2011 10:29 AM
To: Mark Rivers
Hi Mark,
I think you may not need the ezcaIDL.def file. Try renaming it and
rebuilding. If that does not work, try removing the the EXPORTS line and
all lines after it.
Janet
Mark Rivers wrote:
It works, producing an ezcaIDL.dll file that I can use from IDL, but I don't like those warnings. Do you know how to get rid of them?
Sent: Wed 10/19/2011 4:40 PM
To: 'Janet Anderson'
Subject: windows-x64 problem
- RE: windows-x64 problem Jeff Hill
RE: PVManager ReadOnly Check Dalesio, Leo
RE: PVManager ReadOnly Check james.rowland
<2011>
2025
2026
<2011>
2025
2026
