Hi Mike,
On 2011-10-21 Laznovsky Michael wrote:
> Hi- I've built a single *Lib.munch from two separate *.st files, and get
> this error at load time.
> The seqs run fine after this, but I can't use it in a boot script
> because it will abort the boot. A
> lib built from a single *.st doesn't have this problem.
> Loading bin/seqMagCycleLib.munch
> Undefined symbol: pvar_func_Registrar (binding 1 type 0)
> Loading seqMagCycle library failed: S_objLib_OBJ_UNAVAILABLE
> Aborting startup stript.
> value = -1 = 0xffffffff
The symbol pvar_func_Registrar is created by this line in a .c or .cpp file:
epicsExportRegistrar(Registrar);
and pulled into your <app>_registerRecordDeviceDriver.cpp file by this line in
a .dbd file:
registrar(Registrar)
Look for both of those in your source tree; either you're incluing that .dbd
line unnecessarily, or you're not compiling/linking that .c file into your
combined binary.
Also check for warning messages when compiling that .c file; if you've
forgotten to #include <epicsExport.h> then that statement can look like a
function declaration but will at least generate a warning.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- seq lib load error (vxworks) Laznovsky Michael
RE: windows-x64 problem Mark Rivers
RE: windows-x64 problem Jeff Hill
<2011>
2025
2026
Logging change of state for binary input in Message History of CSS ZYCHLA Emmanuel
<2011>
2025
2026
